20-12-2012 #1
Don't laugh but a couple of months ago I had an accident that saw all the balls in a ballnut empty themselves all over the place!
Two things:
Is this even worth attempting a fix considering I've probably lost a ball bearing or two. (I might have them all but these things are so tiny I can't be sure)
If it is worth it then what the procedure for getting them back in? I can see a couple of plastic caps which presumably were used to fill the nut when manufactured but these push through rather than pop out so that rules out filling when the nut is on the screw. Only thing I can think of is drill a hole in the plastic caps and pop the balls back in then seal up with silicon or filler.
If all is lost can you suggest a decent (cheap) supplier of just a 1605 single ballnut? The ballscrew is virtually new so don't want to mess with that.
20-12-2012 #2
try a search on the forum, pretty sure I read a thread on here about someone else doing that not so long ago & yes they managed to get them all back in so worth having a go.
20-12-2012 #3
Hi Shinobiwan,
Do you have one of those cheap 16-05 China ballscrews it is possible to reload the ballscrew. I have done it a few times to load oversize balls to reduce backlash.
Leave those plastic caps in place. If you turn the nut on the ballscew(either end) one revelution you can pull the outer nylon ring and stuff the balls in that way. I would have de-greased everything before i started and keep them away from anything magnetic/dust. I also find it easier to engage the nut a little when stuffing balls.
You might end up with a few leftover balls. But i havent found that to be a problem.
Jan Rune
The Following User Says Thank You to Jan Rune For This Useful Post:
20-12-2012 #4
Yes done that, balls everwhere.
Give the balls and nut a good clean before you start. Count the ball and seperate them into two equal amounts so that you get the same amount in each chain. Hoefully the ballnut has only two chains. What i used was a long pair of tweezers to replace the balls. I also stuck them in a little bit of grease to "glue" them in place when putting them back.
As Martin says there was a thread on this a while ago. A few of us have done it already.
The Following User Says Thank You to Web Goblin For This Useful Post:
20-12-2012 #5
I read a thread on here the other day, the guy said he put a magnet on the nut to help get the balls back in. Just have to make sure that your in a clean environment and de-magnetise afterwards.
Sam
20-12-2012 #6
I've done this a couple of times...
Ideally you want a tube which is the pitch diameter of the ballnut minus the diameter of one ball, so if you imagine the nut fully populated it would just slide inside. You can then hopefully gradually slide the tube in, position the balls in the tracks with tweesers and grease to make them stick. With all the balls inside and the retaining tube, it will be the same as having a new nut, so you just push the tube up against the end of the screw and carefully twist the nut back onto the screw ensuring that the tube doesn't loose contact, else the balls may drop out. You can also try putting the balls in with the nut on the end of the screw and turning it as you go, that's worked for me once.
If you've got a strong magnet then stick it to the side of the ballnut, so when you put the balls in they will just stick to the nut. Ideally, I think you should demagnetise the nut afterwards. Obviously with any of these methods ensure everything is very clean before you start since swarf or just about anything except grease/oil in the nut will damage it over time, and it's sensible to do it in a tray as the balls are bound to fall out again!
On the plus side, it's a good opportunity to clean the ballnut! I've known ones I've got from chai to have small bits of metal floating around in them, which really doesn't help, especially when trying to get zero backlash by preloading...
The Following User Says Thank You to Jonathan For This Useful Post:
20-12-2012 #7
I guess we have all done that! First make a cardboard tube, just roll up thin card, to go over the machining on the screw but will fit in the nut with the balls in. I used the magnets but found that thick grease held the balls in better. you will need a small screwdriver with a dab of grease on the end to place the balls inside the nut. When you have all the balls in place gently push in the tube. I rolled the tube up slightly smaller, pushed it in and let it expand. Then slide that sucker on. have fun.
Bruce
HA! jonathan beats me by seconds........The more I know, I know, I know the less. (John Owen)
The Following User Says Thank You to motoxy For This Useful Post:
20-12-2012 #8
20-12-2012 #9
Just wait, thats all i am saying, just wait
20-12-2012 #10
Haha! Oh yes!
Yep I'd been warned well in advance by Jazz that unscrewing the ballnut off was a big no no unless your a sadist.
So like yourself wilfy I wasn't curious enough to just wind the nut off and look inside. No, instead my accident was more spectacular. This was on the Z, I had no bed to limit Z travel and no floating end ballscrew mount to stop the nut either... cue me playing with motor tuning - a nippy 8m/min with slow slow acceleration. Wound it up to a good speed and then watched in horror as it slowed down like a snail all whilst smashing the Z 'up' button on the keyboard to no avail! Moments later, the Z axis front plate is off the machine and its raining ball bearings! lol Good times.
Humans... we are constantly finding new and inventive ways to f$%k up!
Ps. Thanks guys. I'll have a shot at this I think. Worse that can happen is I fail and go order a new nut.
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
