19-03-2016 #241
Hmmm I think its probably best to disassemble the gantry from the base and re assemble everything checking alignment more strictly as I go...at least I now know it all goes together!
19-03-2016 #242
Right, time to order a DTI (don't shoot me, probably where I went wrong in the first place!). Should I go for lever or plunger type? Lever appears more expensive but if it's going to be more useful then I don't mind. I'm looking here: http://www.lawson-his.co.uk/precisio...ial-indicators
While I'm at it, is there any other piece of measurement equipment (straight edge etc.) that is worth buying for setting things up?
Cheers!!
19-03-2016 #243
I think you could use either to align the second rail. Be aware you also need the connecting rods to hold the indicator in place and ideally a mag base. You can buy Mitutoyo (v good quality) but for DIY I'd look on eBay. You can get a DTI, adjustable rods and mag base as a set for under £20.
Mine were both mid price units from ArcEuro
19-03-2016 #244
Cheers for the help, I was looking at mitutoyo but will have a look at those cheap ones too.
I can't yet see how exactly to use a DTI to align the rails?
19-03-2016 #245
Fix 1st rail by pushing it tight against a known straight edge. If you don't have one you'll have to skip that for now and assume it is straight.
Put one carriage on the rail put the mag base on the carriage and use rods to reach across to the other loose rail and put the DTI touching the other loose rail. Run the carriage on the 1st rail back and forth (which will move the DTI)and nudge the 2nd rail until the needle doesn't move any more. This will at least set them parallel to each other.
08-05-2016 #246
I'm still alive!
Time and money (lack of) have been slowing me down with this project but just ordered the pieces for my control box :)
09-05-2016 #247
16-05-2016 #248
OK, time to start thinking about tooling. Wheres the best place to buy some flutes and am I better buying a set or individual? What are the most common sizes etc? I'm guessing there's not really an answer to that?
07-06-2016 #249
I'm getting very close to finishing....watch this space!
08-06-2016 #250
I'm watching...I'm watching....looking forward to seeing it making chips
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
