    I have been doing some googlehopping to try and find something I need .. its here Pipe As it says in the advert Made of flexible,
    "formable corrugated stainless steel, this product can flex and bend to make just about any shape, and will hold its shape once bent without leaking. It's easy to cut to length with a variety of tools including hacksaws, reciprocating saws, and cutoff wheels".
    I want something like this about 3/4 to an inch bore to use for dust extraction I'm buggered if I can find a UK supplier or if there's another alternative that's used for something else ? Anyone any alternatives I only really need about a foot of it . I did try and make an extractor hood but I don't have the skills ( it fell to bits) so I'm just going to run the flexi pipe down to near the bit and suck up the dust like that. I have used compressor pipe and it worked ok but I cant get the angle i want under the spindle so the vacuum is not as affective. Can anyone help plz ?
    Ralph Waldo Emerson
  2. Try googling flexible exhaust pipe or
    this on ebay
    20mm ID 24mm OD 3/4" Flexi Pipe Tube 1metre Exhaust Flexible | eBay
    Bill
    Quote Originally Posted by BillTodd View Post
    this on ebay
    Bill
    I think that wont hold its shape Bill ? Goose-neck is very close though thanks
    Ralph Waldo Emerson
    I seem to remember that that type of tubing was called "Gooseneck" tubing... Hope googling that will help.
    It would actually be cheaper to buy a flexible lamp for £9.99 and strip of the gooseneck pipe !
    Ralph Waldo Emerson
    The flow resistance for such a small diameter pipe will be high, so even though it is quite short you may have problems depending on what kind of swarf you are aiming to extract.
    Mainly wood dust , I'm only really concerned with the saw / dust.. large chips I'll sweep up after its finished.
    Ralph Waldo Emerson
    go to your gas meter cupboard look at the pipe on the inlet of the meter that is connected to the regulator this is around 3/4 is stainless and is flexible if this is suitable and long enough for you i can get you one minus the regulator and all u would need to pay is whatever it costs to post
    Hi have you thought of using flexible exhaust pipe just looked on the tinternet and found a company Spare Parts for Honda Belle Stihl Husqvarna | Chainsaw Spares | L&S Engineers selling 1.25 " dont know if its ss thou
    Lives in East Lothian, United Kingdom. Last Activity: 51 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Flexible exhaust pipe won't hold it's shape.
    For cheap and easy, some 1" hose taped to a bit (or a couple bits) bent metal wire/bar.
  1. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  2. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 06:47 AM
  3. RFQ: RFQ: Micro Precision in Stainless Steel.
    By mikewatch in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 11:49 PM
  4. What kind of machine will do stainless steel or brass engraving
    By JayPunchbuggy in forum Machine Discussion
    Last Post: 13-03-2013, 10:40 PM
  5. stainless steel fasteners - quality
    By dsc in forum Metalwork Discussion
    Last Post: 30-11-2012, 12:35 PM
