    Hi I have a 1.5kw and am looking at adding the earth cable to the spindle as suggested for the 2.2kw. Question is do I just run a cable from the inside of the plug to one of the three screws on the plastic cap? see pictures for set-up
ID:	8423Click image for larger version.
ID:	8422Click image for larger version.
    So long as you make a secure connection from the earth wire to the spindle body you can do it wherever you want really.
    Quote Originally Posted by Dwayne Dibbley View Post
    That's exactly what I did. It'll be fine but if you want to make sure then once you've wired it up just check continuity by placing a multimeter between the spindle housing and the 4th pin.
    Thread Moved and made sticky !
    .Me
    Maybe merge this thread with the existing chinese spindle one already stickied? The info is one place then.
  2. motor and spindle cable size?
    By paulus.v in forum General Electronics
    Last Post: 04-02-2014, 10:18 PM
  3. WANTED: Chinese 1.5kw spindle/vfd
    By Philly in forum Items Wanted
    Last Post: 10-02-2013, 11:44 AM
  4. VFD Cable and 2.2kw spindle wiring
    By Flamered in forum Spindles & Drive Motors
    Last Post: 24-08-2012, 07:29 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
