Thread: aluminium machining
Hi Guys,
Can anyone recommend a company or individual that might be able to machine some parts out of aluminium at a competitive rate? I've tried a few companies near to me, but they either aren't interested in doing one offs or quote a silly price. I basically want some angular contact bearings set into a block of aluminium with a few mounting holes.
Thanks,
Adam.
14-03-2013 #2
You're probably best off posting in the RFQ section, detailing what you need with a drawing. It sounds like something I could make, but I can't be sure or give a price without first seeing a drawing.
14-03-2013 #3It sounds like something I could make, but I can't be sure or give a price without first seeing a drawing
14-03-2013 #4
14-03-2013 #5
Not surprised your getting high quotes. It looks like a simple part on face value but start to think of how to machine it and your looking at working on up to 3 different orientations, 2 of which would require a a double sided jig to ensure the bearing recesses are aligned to a high tolerance.
My advice would be to redesign the part otherwise you'll either pay a lot or I can't imagine anyone on here taking it on for peanuts.
14-03-2013 #6
For two off, CNC isn't really worth it.
A lathe with four jaw chuck would get the boring done. Bore center bore and one bearing recess, flip, dial in, bore other recess.
Mill would soon sort out the flanges (either horizontal with a slab mill, or vertical with flycutter or large facemill). Then holes can be drilled in a pillar drill.
If they're getting made from sawn stock, you'd have to mill at least 4 faces flat first (you could face the other two in the lathe), and to save set-up time you could machine the flanges at the same time before doing the boring.
A couple notes about the drawings-
1) what tolerance do you need on the bearing bores (i.e. interference, sliding)?
2) if you're putting a 8mm bolt through the flange holes, you need them drilled larger than 8mm for clearance
I could do them, but I just don't have the time.
14-03-2013 #7
Nothing difficult about that - there are various ways to get the bearing bores concentric and machine the bottom face parallel to their axis. It looks like you've chosen 7208 bearings, which are bigger than you need for a 25mm ballscrew - I'd use 7207 instead to reduce the moment of inertia and cost. Have you drawn the rest of it?
Edit: On the rotating ballnut mounts I have made I've tended to make the bearings a light interference fit, but I expect either would be fine. They need to be a sliding fit on the shaft to allow pre-loading.Last edited by Jonathan; 14-03-2013 at 11:35 PM.
15-03-2013 #8
Thanks for the replies and advice guys!
I wasn't really sure the best way to machine this piece, I do actually have a lathe, but I wouldn't really know where to start with getting the piece center....
machining aluminium with 1.5kW spindle
By routercnc in forum Spindles & Drive MotorsReplies: 13Last Post: 15-02-2014, 02:55 AM -
RFQ: Aluminium frame Machining
By mZeles in forum Projects, Jobs & RequestsReplies: 4Last Post: 27-12-2012, 08:17 PM -
Machining Aluminium
By Steff in forum Metalwork DiscussionReplies: 7Last Post: 14-11-2012, 12:48 PM -
Breaking cutters machining aluminium
By ukpete in forum Tool & Tooling TechnologyReplies: 10Last Post: 16-08-2011, 07:23 AM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM
