    hi could someone please advise me on how to paint letters that i have engraved into mfd but the letters are only 15mm high tho.the face of the mdf will be pick and the letters will be black.if someone could make some suggestions on how i could do this i would appreciate it thanks Tom
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hi Tom,
    I would paint it all pink first then pick out / fill in / paint the letters with a small brush.
    If you need to do a batch of these then i would look at making a set of stencils and a jig, i would still paint them all pink first but having a reverse stencil would mean you could airbrush the letters much faster.
    .Me
    .Me
    Quote Originally Posted by cockneyrebel View Post
    Hi Tom, when you say "engraved into MDF" did you mean the letters stand out or are engraved into the MDF forming letter shaped pockets..
    Regards Rick
    hi Rick i mean engraved in the mdf as i say the letters are about 15-20 high and about 3mm wide and 2mm deep
    paint in the letters first, when dry use a gloss paint roller with little paint on it and roll over the top with very light roller motion, do as many coats to look good
    Best to paint the mdf before you engrave it as then when you fill in the black it will not bleed into the pink!
    If you use a resin paint you could fill the 2mm up with the black.
    Peter
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    I think standard procedures for painting text like this is to use a syringe, needle and ink to fill the letter 'pockets'. Mind you this is on metal, so in your case I would paint the piece with waterproof paint to stop the ink sinking into the MDF and when everything is dry, use the ink method.
    Regards,
    dsc.
    Quote Originally Posted by dsc View Post
    Regards,
    dsc.
    Don't know about infilling letters with ink but it was certainly done infilling the letters with paint, normally something like "One Shot" which is a traditional signwritting paint. Once the piece had dried it was then buffed & polished to ensure that it was flat & any high spots in the paint were removed.
    MDF is porous so I would think it would need to be sealed in some way before any painting.
    thanks to everyone who replayed to me i have ago and see the best way to do this and let you know which way is best
    Hey fella, just spotted this video it's towards the end that will give you an idea how to do it. But I found the whole video very interesting.... http://blog.ponoko.com/2011/05/27/br...ecause-we-can/
  11. The Following User Says Thank You to D-man For This Useful Post:
  1. RFQ: 50x Small machined, anodised, engraved plates
    By Husky in forum Projects, Jobs & Requests
    Last Post: 10-03-2013, 12:18 AM
  2. RFQ: Shot blasting or other paint removal
    By craigrobbo in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 12:21 AM
  3. Can you identify this paint on metal finish..?
    By Wal in forum Metalwork Discussion
    Last Post: 29-01-2013, 06:25 PM
  4. Powder coat & paint
    By craigrobbo in forum Metal Finishing Techniques
    Last Post: 06-08-2012, 09:06 PM
  5. Design and machining raised letters
    By compfranon in forum CAD & CAM Software
    Last Post: 11-09-2010, 10:59 PM
