    I reciently picked up one of those Chinese 6040 routers you see on eBay. Worked right out of the box, very pleased! But didn't like the manual control of the spindle... Eventually, I found this gem:
    mach3-plugin-for-huanyang-vfd/
    I got a cheap RS-232 to RS-485 converter (about £3 from ebay) and wired it up with an old cut up usb cable (connected the shield only at the converter end. Installed the plugin and it worked! I can set the spindle speed in Mach3 and get a readout of what the actual speed is. The instructions on website are excelent, so I won't bother re-writing them here.
    As I understand it, I can also add a custom readout to the Mach3 screen to show the current current being drawn by the spindle.
    One gotch to look out for: Make sure the the Huanyang VFD's interface board board has the transevier populated. U4 I think. Mine did, so I was in luck and didn't have to solder one on.
    Hope this helps someone out there.
    Cheers,
    -Jay
  2. The Following User Says Thank You to JayPunchbuggy For This Useful Post:
  1. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
  2. Mach3 ports and pin setup to match my control box
    By Sparky in forum Artsoft Mach (3 & 4)
    Last Post: 13-11-2014, 04:00 PM
  3. can mach3 burnout transistors on a CNC control board?
    By kevinb in forum Artsoft Mach (3 & 4)
    Last Post: 29-11-2010, 04:24 AM
  4. HID interface for remote control of Mach3
    By Smiler in forum Electronic Project Building
    Last Post: 10-05-2009, 12:59 PM
