27-03-2013 #1
Hi all, My Friend has asked me How to Use CNC to cut many items from an 8x4 x 1-2mm stainless sheet, he is making some odd shaped items that have an area of about 6" square but the edge finish has to be precise, and I couldn't think for the life of me how I would do it. What would you guys suggest for the cutting and holding, the nesting isn't a problem..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
27-03-2013 #2
S/S is notorious for wearing cutters out and you have to use slow speeds and high feeds to prevent work hardening. Complicated shapes are best cut using a none-contact method such as water jet, laser or plasma.
EDIT:
Depending on quantity, would it be worth making press/punch tools from tool steel?Last edited by birchy; 27-03-2013 at 08:53 PM.
27-03-2013 #3
Waterjet would be a no no for me, and well Plasma is not out of the question but the finish is not great when I use mine by hand, and I suspect although better with CNC its not that great either although I'm not Certain of that. And laser, well if I could have a laser that would cut 2mm metal of any kind I would jump at that but I understand the lasers cost a packet...
27-03-2013 #4
TBH, plasma would be a last resort as the finish usually requires a bit of fettlin'. Stainless will cut OK on a mill if you use Cobalt tools and suitable speeds and feeds with plenty of coolant.
27-03-2013 #5Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
28-03-2013 #6
Shearing would probably be the cleanest method but it depends how complex the piece is. Another off-the-cuff option is a CNC nibbler. Never seen one, but I'm sure they must exist.
28-03-2013 #7
In 1 to 2mm stainless a laser will give a very clean edge, yes I know they are expensive but you sub con the job out and pay by the cut inch [ or mm ]
John S -
28-03-2013 #8
Here you go, one of these would probably do the job.
EUROMAC CNC PUNCHING MACHINES - YouTube
28-03-2013 #9
28-03-2013 #10
RFQ: Water or laser cut stainless flanges
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 2Last Post: 23-09-2013, 08:12 PM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
RFQ: 16mm long stainless pins with m5 tap
By dazza in forum Projects, Jobs & RequestsReplies: 12Last Post: 11-03-2013, 03:12 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM -
Mini lathes - possible to turn stainless?
By HankMcSpank in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 03-08-2010, 03:14 AM
