    Hey guys
    Does such a thing as a stumpy 3.5mm drillbit exist?
    I need to drill some holes that are only around 15mm deep and I could do with not having all the flex of standard long drillbits.
    I have seen stubby drills before just not this size.
    Search for stub drill
    John S -
    Phantom Drills by Boneham & Turner do a wide selection. Not the cheapest, but if you're doing alot in a certain material it pays to get the right drill.
    the short drills are often referred to as "jobbers", cheap but not usually the best quality. G.
    Jobber drills are standard length drills (at least in the last catalogue I seen them....)
    You are correct m_c. I have just googled it and the shortest length bits are referred to as screw machine length, although that may an American term. of course John S is right -stub drill-. Sorry. G.
    I have a ton of short drill's, usually after they have snapped off...
    Yea an option maybe to cut some down and re-grind them ?
    .Me
    .Me
    twin end drills are fairly strong. Used them for drilling sheet steel when normal drills snap on break through
    Twin End Drills
    Sealey AK9910 Double End Drill Bit Set 10pc 1/8" (AK-9910)
  1. CNC drill bit conundrum...
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 06-07-2015, 04:37 PM
  2. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 07:45 AM
  3. pillar drill?
    By wilfy in forum Machine Discussion
    Last Post: 10-11-2012, 09:18 PM
  4. best drill bits
    By oadamo in forum Tool & Tooling Technology
    Last Post: 01-01-2011, 11:25 PM
  5. Dowel Pin Drill jig
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:34 AM
