Thread: spindle interferes with steppers
Morning
ive been having some problems with my diy cnc,i can jog the machine back an forth fine with vfd on but when i power up the spindle all axis judder when moving,the vfd was mounted to the machine with no problems for several months now after the problem started ive moved and mounted it to the back wall and with the vfd cables suspended from the ceiling to but its still doing it
the vfd is operated manually and not through mach and im using shielded cable.
maybe its something obvious to you lot,,im absolutely naff with electronics.
01-05-2013 #2
Howdo,
I have had similar issues with my Yakasawa VFD driving a small 3/4HP 3-ph motor. The issue was caused by the EM crud being emitted from the mains wiring out of the VFD. To cure the fault, I used a mains EM/RFI filter similar to ebay 161015962556 - mounted directly at the terminals of the VFD with only a couple of inches of mains wiring. The other thing that helped was the use of shielded 4 core cable up to the motor, with the shield being grounded at the VFD end only.
I hope that helps!
regards,
Paul.
01-05-2013 #3
thanks a lot paul,got a chap coming down in a few days to look at it, im sure he,ll fave a fit when he sees the wiring i'l take a look at that filter.thanks
17-10-2015 #4
19-10-2015 #5
19-10-2015 #6
19-10-2015 #7
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Emco 5PC steppers
By Ian Hart in forum Stepper & Servo MotorsReplies: 17Last Post: 26-02-2010, 02:47 PM -
Mariss Freimanis Steppers vs Servos Advantages/Disadvantages of both
By Lee Roberts in forum Stepper & Servo MotorsReplies: 0Last Post: 02-10-2007, 09:08 AM
