So finally I've got round to starting this build log (to help motivate me to finish the build!)
The specs -
Cutting area of 3050mm x 1525mm x 150mm
Aluminium/Steel Construction
Hiwin Linear Guides (25mm & 15mm)
Rack & Pinion all 3 axis
Closed loop steppers (through belt reduction 3:1)
1.2kw HF Spindle
Option for tangential cutting knife
USBCNC software CPU5B
Full Vacuum Bed made from aluminium box section.
So now you know where I'm going, this is what you all want, PICTURES! Click image for larger version.
ID:	8938Click image for larger version.
ID:	8939Click image for larger version.
ID:	8940Click image for larger version.
ID:	8941Click image for larger version.
ID:	8942Click image for larger version.
ID:	8943Click image for larger version.
ID:	8944Click image for larger version.
ID:	8945Click image for larger version.
ID:	8946Click image for larger version.
ID:	8947Click image for larger version.
ID:	8948Click image for larger version.
ID:	8949Click image for larger version.
ID:	8950Click image for larger version.
ID:	8951Click image for larger version.
ID:	8952Click image for larger version.
ID:	8953Click image for larger version.
ID:	8954Click image for larger version.
