    Hi, I am looking at buying a 24v psu to run the safety / emergency circuit on my cnc router. Any recommendations? There's loads on eBay but what is the correct amp to go for?
    Same question for the 5v supply for the bob.
    I will be building my 70v psu to run the drivers / motors, is it worth making the 24v psu or isn't easier / more cost effective to buy one?
    Cheers!
    Dan
    The currents required for the breakout board, and 24V for other bits, are generally low so around an amp would be fine. It's best to work it out properly though - exactly what are you connecting to the 24V circuit? Relays?
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    ohlookyetanotherone
    Thanks guys,
    The 24v system will be running 4 limit switches, 4 home switches (also acting as limit switches), 2 e-stops, running lamp and relays to cut the power to the 70v motor system.
    Dan
    Should probably start a new post for this, but on my home made 70v psu / transformer should there be an earth wire connected or will it be earthed via the metal cabinet? What do people normally mount the components on to?
    Dan
  1. Replies: 0
  2. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  3. Custom power DC supply
    By M250cnc in forum Electronic Project Building
    Last Post: 22-11-2010, 09:48 PM
  4. power supply problms
    By Scott in forum General Electronics
    Last Post: 11-07-2010, 12:58 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
