    I am milling some gears from various types of plastics - one of the gears needs machining on both top and bottom. Obviously when I take the part out to turn it over, I struggle to get it perfectly aligned - I was thinking of making some kind of a jig - not sure.
    Is there a holding device that allows you to flip a part over and still have it perfect based on where the previous centre mark would have been?
    Could you not just machine a couple of dowel holes through the part into the table before you cut it, then flip it and dowel it again?
    That is one option - I could also use a set of right angled sections but the issue is that the item is round and you ideally need to have it not rotate either.
  4. Surely if its a gear the central hole and/or boss plus an offset dowel hole would both register and locate it.
    Or perhaps cut the back side first and leave a spur with dowel hole which is cut off on the front side.
  1. bumping holding current - how it affects torque?
    By dsc in forum Stepper & Servo Motors
    Last Post: 03-02-2014, 04:11 PM
  2. denford orac tail stock dimensions
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 24-11-2013, 10:42 PM
  3. RFQ: RFQ: Keyslot milling in alu round stock.
    By Saracen in forum Projects, Jobs & Requests
    Last Post: 05-09-2013, 09:42 AM
  4. Holding down sheet material.
    By jcb121 in forum Machine Discussion
    Last Post: 03-07-2013, 12:11 AM
  5. holding mdf down to bed
    By kell in forum General Discussion
    Last Post: 13-07-2012, 02:59 PM
