    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Hi all,
    planning to buy a 2L ultrasonic cleaner for various small parts, cleaning old tools etc. Browsing the net I've found a lot of cheapo China made models on ebay for around £100 and super expensive lab grade stuff for 4-5 times more. The cheapos are 50W for the transducer and usually have 50W heaters, which apparently fail quite quickly and are close to useless.
    Curious if anyone here has got one which works and didn't cost an arm and a leg or has some suggestions?
    Regards,
    dsc.
    I got one of the exceptionally cheap ones from Aldi and it seems to work. I've not got anything to compare it with though.
    dsc's Avatar
    That's the thing, I'm not sure whether there's much difference between the super cheapos (<£40) and mid cheapos (~£100). I've found this teardown:
    EUMAX digital ultrasonic cleaner - teardown and review - Page 1
    did some research and found that the company is Chinese, but they do offer the 2L version with a more powerful 80W transducer (not available in the UK though), most cleaners on ebay offer 50W:
    TATTOO GRIP & ACCESSORIES ULTRASONIC BATH 1.8ltr 50w BRAND NEW CLEANER | eBay
    Is it possible to replace the original transducer with a more powerful one if needed, or does it involve changing the electronics as well?
    Regards,
    dsc.
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    I bought a 2l one for £80 a few month back.
    Heater is pretty much next to useless for heating up cold water when running full, so i ended up mixing solution up with boiling water as what I was cleaning needed a few water changes. If you wanted to reuse the solution from cold, then you need to turn the heater on a good bit before you plan to use it.
    dsc's Avatar
    Did you get yours from ebay?
    For the solution I was thinking, plain hot water in the tank and a bag full of cleaning solution / parts sitting in the water. Apparently the vibrations get passed on and you don't contaminate the main tank that way.
    Regards,
    dsc.
    Yeah. I just picked whatever ebay seller had the size/shape I wanted at the cheapest price.
    That is one way to do it. What I was doing needed the full capacity and the solution was saturated with oil/carbon within 10min, so I had to keep changing the whole lot.
  1. broken ultrasonic cleaner?
    By graffian in forum General Electronics
    Last Post: 21-11-2012, 01:02 PM
  2. NEW MEMBER: Good day all!
    By icedfusion in forum New Member Introductions
    Last Post: 07-10-2011, 08:38 PM
  3. is this kit any good
    By deannos in forum General Electronics
    Last Post: 26-03-2011, 09:17 AM
  4. Dyson Digital Motor (Vacuum Cleaners)
    By bogflap in forum Tool & Tooling Technology
    Last Post: 21-07-2009, 10:03 AM
  5. NEW MEMBER: Good Day All
    By Mad Professor in forum New Member Introductions
    Last Post: 07-06-2009, 10:13 AM
