Thread: Warco Major CNC build log
13-09-2009 #16
Today I reworked the tapered Gibb strip fixings.
The original adjusters are totally naff allowing the the Gibbs to move, so they went from tight to loose as you reversed direction on the slide :nope:
To fix it I fitted 35tpi x 3/8" studs, screwed the adjusters on to them, (still sloppy) then bolted on end caps to pinch it all together... TIGHTLast edited by Robin Hewitt; 13-09-2009 at 02:49 PM. Reason: Edit: Wrong pitch, brain fugged
Haighton Major
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 25Last Post: 14-05-2022, 02:17 PM -
WANTED: Conect Minor or Major CNC Milling Machine Wanted
By stevy123 in forum Items WantedReplies: 0Last Post: 24-08-2011, 10:35 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
