    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    I have blender. never used it. I have the script than is supposed to go in the "python console". tried it dozens of times, cant get it to work and I don't know what I am doing At All in that software.
    There must be an easier way to convert this. Maybe not free.
    Anyone know of maybe a 15 day evaluation software that allows the export of the mesh file please ??
  2. Have you tried using Rhinoceros?
    I know JazzCNC (Dean) uses it, and I am sure he will post in due time.
    "If first you don't succeed, redefine success"
  3. The Following User Says Thank You to Mad Professor For This Useful Post:
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #4
    Yes rhinoceros will do this and they used to give free unlimited functions demo limited to 28 saves no time restriction.
  8. #5
    dudz's Avatar
    I have searched google but have not come up with a solution for this small issue.
    I ran the digitizing wizard in Mach3 twice. The txt file is completely empty after both attempts. The properties show 0 bytes on the file.
  1. Mach3 digitizing wizard not saving file
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 08-09-2013, 09:48 PM
  2. Digitizing probes practicality
    Last Post: 04-06-2013, 03:31 PM
  3. Mesh cam or other?
    By totts in forum CAD & CAM Software
    Last Post: 26-08-2011, 04:57 PM
  4. Probing / Digitizing - What the best way to do this job?
    By Mad Professor in forum Probing, Digitizing & Scaning
    Last Post: 08-05-2011, 12:32 PM
  5. Digitizing
    Last Post: 06-01-2011, 06:52 PM
