Thread: Ready Steady Eddy
03-02-2014 #161
I'll take the paint off where the epoxy will go with a flapper disc on the angle grinder so it's back to bare metal. I guess the epoxy would be OK when the paint was in the oven (180°C) but will get it painted before just in case.
I know this is somewhat less than scientific but I just had a play with the sample epoxy pour I did 3 days ago, a scriber barely scratched the surface and a centre punch made no more of a mark in it than it did in the steel box section. Overall I'd say that stuff was rock hard.
03-02-2014 #162Spelling mistakes are not intentional, I only seem to see them some time after I've posted
03-02-2014 #163I'll take the paint off where the epoxy will go with a flapper disc on the angle grinder so it's back to bare metal. I guess the epoxy would be OK when the paint was in the oven (180°C) but will get it painted before just in case.
03-02-2014 #164
That's good to know Clive, will save a few slips with the flapper disc that's for sure!!
03-02-2014 #165
I think a bearing guided bit would work but that wasn't quite what I had in mind. I'd try a chamfer bit with the depth set slightly less than the depth of the epoxy. Run the fence of the router along the edge of the steel. You'd probably need a couple of passes as the leading edge of the router would ride up a little but I'd guess it'd take longer to set up the router than it did to clean up the epoxy. I think this would probably work better with the more often used clamping-wood-to-the-steel method of keeping the epoxy in while it's poured as you wouldn't have to be quite so careful about correctly setting the depth of cut.
Great looking result Eddy.
03-02-2014 #166
03-02-2014 #167
04-02-2014 #168
It's been cold overnight here recently so this is the third day since pouring the epoxy, it's set but I'm not confident about taking the moat off just yet.
11-02-2014 #169
Must be about time for an update???
11-02-2014 #170
Yeah c'mon eddy! How are the rails looking?
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
