Thread: Ready Steady Eddy
25-03-2014 #241
I ordered it from Igus thinking it would be here next day or 2 days most, had I known earlier it would be like this then I'd probably have gone to China for it like you say.
25-03-2014 #242
25-03-2014 #243
There was a time when I used to order hundreds of metres of great big chain and also their flexible cables but times and people(reps) change.
26-03-2014 #244
Gave me time to get the fans fitted anyway, something I was not looking forward to but not as bad as I thought. I'll probably fit a thermostat with a remote sensor in the hood.
Two fans mainly because I already had them but they are 110 Volt so just wired them in series. Made a box with a sliding lid to allow easy replacement of filter medium, the fans are blowing into the panel pulling air through the filter medium. A vent at the top allows heat to escape by convection or forced by the fans, it does not allow crap to enter under gravity.
The wiring will have to be kept to the back of the panel as much as possible so as not to interfere with air flow.
(just ignore the temporary lashed in wiring)
26-03-2014 #245
I like that top vent, do you have a source for them?
I'm hoping they come in 80mm square versions. I currently have regular fan filters at the top to stop crud getting in but I think the air flow restriction they cause will be too great so a vent like that would be perfect. The alternative is to fit a couple more fans at the top but that then risks creating a negative pressure in the case.
26-03-2014 #246
29-03-2014 #247
Eddy noticed you have wire tags or numbers on your wires where did you get those.? . . . I've looked around but can't find any at sensible money.
29-03-2014 #248
Got this type on ebay
Cable Tie Ident Nat 100mm Pk100 - Price For Pack Of 100 - MCV100 | eBay
29-03-2014 #249
29-03-2014 #250
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
