Page 1 of 4 123 ... LastLast
    I pulled apart my controller just to check a few things ahead of my modifications and have made a schematic for it, it may be useful for people with the same board.
    This is the board...
    It is simply marked Tonsen 4 Aixs Con (They probably mean Axis )
    This is the schematic...
    A few things to note...
    • The Q817 Opto-isolators, RN2 and Input header are not actually fitted as you can see from the board picture.(Top right)
    • The power input is marked as 24v AC but it is DC.
    • The caps are marked on the PCB 1000/35 for C1, 470/25 for C2 & 220/16 for C3 but the values in the schematic are fitted.
    • The moto(spindle) header is on the board but it doesn't connect back to the spindle controller.
    In summary pins 2,3,4,5,6,7,16,17 are buffered through the HC244. Pins 1,8,9,14 are connected directly to the parallel port. Pins 10,11,12,13 & 15 could easily be converted to opto-isolated inputs with some extra components.
    The one thing that puzzles me is the Enable pins, in the manual is says to turn on Enable 1 & 2 and set them to pins 8 & 9. These control the Y & Z axis, but pin 14 which is connected to X & A is not mentioned, and I don't currently have this turned on in Mach3.
    Anyway use this information at your own risk, I am NOT an expert, always double check your board and pin outs.
    Regards,
    Les
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Do you think that the board will accept AC or DC as there appears to be some half wave rectification at the front end. ..Clive
    I don't know to be honest, but it wouldn't surprise me if it were just a mistake. After all the port on the back of my controller is marked 'Parakkel Port', and they did spell Axis wrong!
    Regards,
    Les
    It says AC beside the socket and as Clive says the diode would indicate this is true.
    Pin 1 gets used for all sorts, on my bob it is the charge pump. on others it is marked 'strobe' or 'spindle enable' or operates a relay for 'spindle forward'.
    Updated schematic in first post as I made a small mistake with RN1.
    I am sure it's DC going in, my Multimeter showed 0 for AC and 24v for DC. It's also coming from the same PSU that drives the stepper motors, wouldn't that be DC?
    Regards,
    Les
    Either would do but in this case 24v ac 1/2 wave would barely provide enough input for the voltage regulator so as you say Les it must be 24v dc
    Well spotted ..Clive
  8. Quote Originally Posted by EddyCurrent View Post
    the diode is purely for reverse polarity protection. Too many mistakes would give me quality concerns...
    Irving, that is correct I forgot about that, many years ago some car radios used to have the same.
    I assumed that's what it was for but as stated I am no expert.
    Spelling mistakes are fairly normal for cheap Chinese stuff (you should try and read the manual), but they do not make me worry about the quality.(Touch wood, so far, the electronics have been good)
    Regards,
    Les
  1. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  2. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
  3. Reversed axis on a AXYZ 6010 after installing DNC controller software...
    By RickyThunders in forum Machine Control Software
    Last Post: 12-02-2013, 03:56 AM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
