    so, here are some parts I've made, hopefully they'll be some use to you lot.
    2.2kw spindle.dwg
    bf12 ballscrew mount.dwg
    bf12 ballscrew mount.dxf
    bk12 ballscrew mount.dwg
    bk12 ballscrew mount.dxf
    nema 23 3.1nm.dwg
    nema 23 3.1nm.dxf
    sbr20 bearing block.dwg
    sbr20 bearing block.dxf
    sbr20 Rail.dwg
    80mm Spindle Clamp.dxf
    80mm Spindle Clamp.dwg
    2.2kw spindle.dxf
    15t HTD 5mm 15mm pulley.dwg
    15t HTD 5mm 15mm pulley.dxf
    16mm ball screw mount.dwg
    16mm ball screw mount.dxf
    16mm ballscrew.dwg
    16mm ballscrew.dxf
    30t HTD 5mm 15mm pulley.dwg
    30t HTD 5mm 15mm pulley.dxf
    sbr20 Rail.dxf
    enjoy.
    dwg's are in autocad 2014 and dxf's are in 2000.
    THESE MODELS MAY HAVE DIFFERENT LAYERS. I ADVISE DELETING THE EMPTY LAYERS
    the ball screws use a 25mm pitch but they have two flutes to make them look good.
    the pulleys are based on a circular array, so while it has the correct amount of teeth, they're likely to be the wrong size.
  2. The Following 2 Users Say Thank You to jcb121 For This Useful Post:
  1. Replies: 8
    Last Post: 01-02-2014, 09:33 AM
  2. Concentric reducer in autocad
    By Web Goblin in forum Computer Software
    Last Post: 24-09-2012, 03:58 PM
  3. AutoCad 2007
    By D-man in forum CAD & CAM Software
    Last Post: 05-08-2012, 05:51 PM
  4. time to gather parts for new machine
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 21-01-2012, 02:23 PM
  5. Does anyone tell me the main parts of CNC Milling Machine?
    By hoezap in forum General Discussion
    Last Post: 07-11-2011, 01:25 AM
