    Hello,
    I am trying to calculate the required plunge depth for a v cutter needed to produce a given diameter of hole.
    Can someone explain the formula I need?
    Thanks!
    EDIT:
    Answer:-
    Z = Depth of cut
    d = Required diameter of cut
    a = Cutter tip angle in degrees*
    f = Flat spot
    r = Tip radius
    V Groove type cutter with no flat spot.
    Z=d/(2*tan(a/2))
    V Groove type cutter with flat spot.
    Z=(d-f)/(2*tan(a/2))
    V-Groove type cutter with a radius tip.
    Z=r-(r^2-d^2/4)^0.5, for Z<=2r
    Z=r+(d-2r)/(2*tan(a/2)), for Z>2r
    Ballnose type cutter.
    * The TAN() function in some applications (such as Excel) require the angle to be expressed in radians, Not degrees. Convert degrees to radians - Radians = angleInDegrees x (PI/180)
    So in excel the first formula above would become:-
    Z=d/(2*tan((a*(PI()/180)/2))
  2. The Following User Says Thank You to cncJim For This Useful Post:
  1. Replies: 0
    Last Post: 05-12-2013, 07:28 PM
  2. Will this end-mill plunge?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 26-02-2013, 04:40 PM
  3. Z axis not cutting to required depth
    By dinasblu in forum Machine Discussion
    Last Post: 02-07-2012, 05:38 PM
  4. Taking the plunge
    By Robin Hewitt in forum Computer Software
    Last Post: 14-05-2010, 01:22 AM
  5. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
