  1. probably like most I cant afford one of these expensive wireless tormach or renishaw probes, so I made my own (with the help of a friend)
    I purchased one of these
    http://www.tormach.com/product_tts_passive_probe.html
    its comes with a long cable which you need to hard wire into you control system to work, it works great but the cable is very annoying. so a friend made a IR sender and receiver that can connect to any control system. I use a pmdx126 and the setup for a probe is dead easy. connect the probe directly to the board and all it does it act as a switch, so mach3 knows when its been triggered or not.
    the receiver board just uses a relay as the switch so it can connect to any control board.
    heres a video of the setup in action, its a very rough setup just to test proof of concept. next I plan to integrate properly
    I have had some Quantum Tunneling Compound for a while now, and my to-do list has a QTC touch probe project (not started - status - don't hold your breath).
  1. New cheap touch probe of fleabay
    By Robin Hewitt in forum Probing, Digitizing & Scaning
    Last Post: 19-08-2015, 09:36 AM
  2. Touch Probe Project
    By Washout in forum Tool & Tooling Technology
    Last Post: 20-11-2013, 12:59 PM
  3. Touch probe stylus - where to buy?
    By Mad Professor in forum Marketplace Discussion
    Last Post: 05-08-2013, 07:07 PM
  4. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 01:16 AM
  5. RFQ: Touch Probe - Lathe job
    By cooliced in forum Projects, Jobs & Requests
    Last Post: 16-11-2011, 07:12 PM
