30-12-2013 #1
Curious what people use on aluminium to hold DTIs? I'm trying to measure a few things with a DTI on a machine which is made from aluminium / 316 stainless and of course mag bases don't stick to anything. I've tried clamping the base, but access is very tricky and measurements are not reliable. What the normal approach to such a problem?
Thanks in advance for any help.
Regards,
dsc.
31-12-2013 #2
Vacuum clamp, like the base on this vice, but only works on smooth surfaces.
Edit: look here VACUUM CLAMP BASE ONLY
expensive tho...Last edited by irving2008; 31-12-2013 at 12:08 AM.
31-12-2013 #3
DIAL INDICATOR HOLDER VACUUM SUCTION BASE FR GRANITE | eBay
122001 Diamond Core Drill Bit Vacuum Base Guide - Ceramic Marble Glass Tiles | eBay - + modify to suite ?
Car Camera Suction Cup Mount Vacuum Base Action Camera Holder VacMounts | eBay
Buy Bases & Arms Noga centre lock vacuum base RS DG 1040 online from RS for next day delivery.Last edited by EddyCurrent; 31-12-2013 at 12:18 AM.
31-12-2013 #4
I clamp a dial guage to a surface guage column and hold the base down firmly to take measurements, for awkward situations I've used a variety of woodwork clamps, ratchet straps and spare stock to hold bases down - if none of this is possible discrete tapped holes are a consideration,
- Nick
31-12-2013 #5
Vacuum clamps - looks neat, but a bit costly. I guess I just need a few more clamps of different sizes, a few DTI holders and keep doing what I was trying before. I do often use a V-block, clamped to the surface, with a round rod clamped in the V and a DTI on the end. Not very flexible, but a full blown, even miniature mag base cannot be clamped / won't fit in the tight spaces due to the length of the rods.
Regards,
dsc.
31-12-2013 #6
Uses compressed air, also shows use for cnc work
V-Clamp, Vacuum clamps powered by compressed air.
02-01-2014 #7
If only I had a source of compressed air Eddy:)
Regards,
dsc.
11-01-2014 #8
I stick magnetic base to spindle and use for mesurement on aluminium part
Rotary broach tool holders and tooling
By dazza in forum Tool & Tooling TechnologyReplies: 5Last Post: 06-12-2014, 01:06 AM -
FOR SALE: New NT-APU Drill Chuck Holders are for sale!
By jille in forum Items For SaleReplies: 0Last Post: 13-03-2012, 08:52 AM -
BT 35 tooling and DA holders
By Kai in forum General DiscussionReplies: 0Last Post: 19-07-2011, 03:22 PM -
WANTED: Tool holders for T2 (I think) quick change toolpost
By Jonathan in forum Items WantedReplies: 22Last Post: 07-05-2011, 10:30 AM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
