Hi all,
Im trying to generate a toolpath in vcarve for a topography map to be milled in wood, something similar to the attached picture.
If 2 layers happen to stack up on the Z axis with a straight line, that's not a problem. However if the vertical stack is a curve is there anyway to copy a section of the path 'above'.
In the below example, assume a block 20mm thick, with section 1 on the face, section 2 being a 5mm cut, section 3 being a 10mm cut etc. Where 1 meets 2, I cant seem to 'close' the vector for part 2.
Any help or advice would be greatly appreciated.
In case you don't get an answer here, have you asked this question on the Vectric forum ?
Vectric Forum • Index page
04-01-2014 #3
Just waiting for my registration to be approved !
04-01-2014 #4
05-01-2014 #5
I don't use V-carve pro but I would imagine separate Vectors on differant layers would easily sort that out.?
05-01-2014 #6
05-01-2014 #7
Hi both,
Yes I think you are right with seperate vectors on different layers, I'm just struggling to make the vector shapes identical for the small portion where they 'touch'
I imagine it can be done by copy/paste and manually cropping but just wondered if there was a smarter way to go about it.
Thanks for the input so far
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
Google Sketchup >> Vectric VCarve
By kingcreaky in forum Computer SoftwareReplies: 9Last Post: 09-03-2013, 07:42 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Vcarve to Mach3
By jcb121 in forum VectricReplies: 6Last Post: 01-04-2012, 05:21 PM -
Playing with VCarve pro and simulations
By John S in forum CAD & CAM SoftwareReplies: 2Last Post: 05-04-2010, 11:37 PM
