Thread: Chinese 3040T Arrives
21-06-2014 #111
Nice pickups Gregor! Have you got a CNC coil winder too?
I used my cnc router & 3 hall sensors to scan a pickup's magnetic field. The one and only benefit of having a rubbish MDF machine is that it does not distort the magnetic field!
Link to project
22-06-2014 #112
Hi NB70
No I don't use the cnc to wind pickups I have made a pickup winder so I can scatter wind them it takes about 6mins to wind them at about 1200 rpm
11-07-2014 #113
11-07-2014 #114
Hi jimbowley
my spindle on my machine only goes up to 8000, the cut depth is 0.8mm and it cuts the phenolic board pretty good, I did cut some plastic with it and it melted the plastic but I found if a used a little bit of wd40 it was fine I haven't used it on delrin. The end mill I mostly use is 1.5mm but have used 3mm for removing material. I am sure other members will give you better advice on what to try as I am really only a beginner.
11-07-2014 #115
The largest you can fit in the spindle.! . . . . . . With cutting plastic like Gregor mentions heat will be the problem but this is just a function of chip load and finding the best setup that suits machine/material/cutter unfortunatly it's not an exact science and very M/M/C dependant. Often when people are melting they are cutting to shallow or too slow and with RPM too high or some combination of all three.
If you use the correct type of cutter with a decent spindle and 10-12mm cutter then there's no reason why you shouldn't rough out 16mm nylon in 3 passes. One problem with nylon is that it can wrap around the tool so having air blowing helps clear this and also gives a slightly better finish. Taking deeper cuts makes bigger chips and this also helps but means going slower so soem experimenting is needed to find best balance.Last edited by JAZZCNC; 11-07-2014 at 05:57 PM.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
BUILD LOG: From Chinese to Taffynese
By Carlb1058 in forum DIY Mill Build LogsReplies: 6Last Post: 09-07-2013, 12:03 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
