Hi Folks,
I am contemplating my first manual to CNC lathe conversion.
I more or less understand the requirements for basic X & Y axis motion, however, I have not figured out what needs to be done to cut threads on a lathe.
I suspect that the spindle needs some kind of rotation sensor, but would that be simply to sense RPM or would it need to be more along the lines of a full rotary encoder of some type, so that MACH3 knows the exact rotational position.
Can this be achieved without getting into the initial extra expense of a motion controller.
Yes some sort of angular velocity sensing is required for the spindle.
Unfortunately Mach3 apparently only works with 1 pulse per revolution sensors, which can work if the spindle inertia is high (i.e. big lathe), or the length of the thread is short. However LinuxCNC supports sensors with many pulses per revolution - it's limited more by the interface (parallel port generally), not the software.
The sensor needn't be anything complicated. Position an infra-red LED and detector either side of a disk with slot(s) in it attached to the spindle, and wire it up to one of the inputs on your controller.
Do you allow price check threads?
By dynamis_dk in forum Marketplace DiscussionReplies: 27Last Post: 16-04-2014, 10:07 PM -
RFQ: Dublin, IRL Manual milling & lathe work required
By 250rri in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-01-2014, 01:07 PM -
RFQ: Lathe Work Required, Small Batches,
By Ptee in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 06:13 PM -
where are the Mach3 discussion threads located ??
By John S in forum General DiscussionReplies: 6Last Post: 01-08-2012, 01:26 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
