Page 1 of 3 123 LastLast
    This is my second post and am making a 700 x 900 x 150 Mill. I have made the frame and gantry and (groan) I bought the Longs TB6560 (4 way) with nema23 hs8610 motors and S201-24 PSU for £108. I had read a lot about the poor board but figured if I bust it during my learning process then no great loss and buy something more appropriate.
    I have got as far as loading up Mach3 and have got the motors and board all wired up on the bench and parallel port connected. I have tried running the 'roadrunner' gcode sample and the X & Z axis move but the Y and other motor (A C 4? no surprise..) doesn't move.
    I am getting very hot motors even when not working.. apart from the Y which is cold. I have swapped over the X and Y motors and all the motors seem OK. It seems to be the Y channel on the board that is duff..
    I had the DIP switch's all on 6 to start and thought that might be too much (I don't really know yet what they do..) So I turned them all off apart from No.6.. Motors still move but looks a lot slower.. Is that what happens..?
    They are 6 wire motors and as by most information gleaned I have insulated off the Yellow and White and just connected red/blue and green/black in the way described in Longs piddly cd.
    I followed their instructions on the 'Ports and Pins' and feel that this could be where my problem lies.
    I could supply their suggested Pin No's if that helps..
    I have read other posts suggesting alternatives but am a bit out of my depth here..
    I do not know whether each set-up is unique or there are common points that someone else's set-up can advise me..
    All help most appreciated..
    Using this info;
    http://www.aliexpress.com/item/nema-...499066426.html
    http://www.fozztexx.com/CNC/HY-TB3DV-M_3Axis_Driver.pdf (this is for 3 axis but I'm sure it still applies)
    I think as a starting point you should set the DIP switches to this (in order 1 to 6, OFF OFF OFF ON OFF ON )
    The motor wiring sounds okay, you have it in 'high torque' mode.
    Follow the Mach3 settings in the document.
    Quote Originally Posted by Marlin View Post
    Eddy's suggested settings are a good starting point but must say your going about this all wrong by turning on very flakey drives with no clue how to set them up or what your doing.! Guessing at these things is just asking to let out the magic smoke and these drives are full of smoke just bursting to get out.!
    Sorry to say this after the event and probably not what you want to hear but still needs saying IMO.!! . . You have really wasted £108.! Even if they survive your best efforts to kill them the performance you'll get will be rubbish with only 24V and motors with 14mH inductance.
    Cut your losses now and sell them before you kill them and buy some decent gear because with machine having dimensions of 900 x 700 you'll want half decent gear on it otherwise you'll be really dissapointed with it when it could probably be so much more.? (depending on build quality)
    Trying to do it on the cheap in case you blow things up is completely the wrong way to go about it.! . . . Separate drives are no harder to wire than all-in-one boards and they are far more tolerant and robust than TB based drives and can be cheap if you shop around.
    Cheap motors are often very low quality just like those you have with high inductance which plays a major part in the performance you can get out of them. PSU's are cheap enough if you look around Ebay and not at all difficult to build if your that way inclined.
    Your much better off waiting and saving for the real thing than wasting money and getting frustrated or turned off CNC by cheap nasty toy town electronics.!!
    Thank you for your responses. Eddy's links.. 1st.. Yes, that is the motors I have.. 2nd link is the information I have on the CD that came with the kit which I followed very carefully before turning on.
    I have emailed Longs and have just heard back from them saying this may be out of date and will be sending me a (new) Datasheet.
    Also after more faffing about with my kit I realised the heat was being generated by the Motors vibrating but the shaft not moving so assumed I was caught in some software loop.. Things seem to want to work but I just don't have the ducks in the right order.
    Jazz, I have read a lot of posts (here and elsewhere) and it seems nothing is problem free. I dithered a lot before deciding to go cheap. I figured the Motors were probably the simplest component and could be used again with better Drives and at this price (£108) I was getting the TB6560 for free. I found in life paying more for something doesn't necessarily get you something better. Hence, the learning curve. Anyhow, I am sure I have read posts with you chastising someone for spending too much and wasting money..
    I am not embarking on this build so much to learn electronics because I don't think I ever will, I just want a working machine that I can reasonably understand and modify in the future. I am better at the practical construction stuff.
    If anybody else has any experiences with this set-up I would like to hear your tales. Thanks
    That's normal, also they will get hot but generally only after being put to work for a while, that's what mine do anyway.
    You didn't say if the new settings had any effect.
    Hi Eddy, Sorry about delay, I had to go to Waitrose.. (ok, Lidl's.. I'm not made of money..) and have taken your advice on the DIP switches.
    I have just started running the RRunner gcode and the X axis seems to be doing fine following the DRO..
    The Y axis is dead, I shall see if I can acquire a different PP Cable to see if that is the problem.
    The Z axis looks fine as well. Small movements that relate to DRO.
    (At this stage I have no idea how the Shaft rotation marries up with distance moved but I am sure that will become apparent.)
    When I start the RR the 4th motor does the Vibration jig which is worrying as there is no DRO movement.
    When I hit RESET to halt the program everything goes quiet and stops.. No continuing vibration from any Motor..
    When I try to restart the program all (not Y) start a whining noise.. prior to the program continuing.. Is that normal?
    As much as I am unfamiliar with Stepper motors, the heat that seems to be being generated even when not running the GCode seems excessive.. Too hot to touch after a few minutes..
    I am used to regular Machine motors and, as you say, will generate heat during a work period.
    I assume I could use Channel 4 instead of Y with a bit of re-routing..?
    One final question.. On the set-up (Foxtech you linked..) it shows specific Numbers in specific boxes when setting up the Ports and Pins Motor Output, Input Signals and Output signals.. I have taken these on screen No.s as the Correct No.s to insert as I have no other list of No.s to refer to.. (Unless I get something useful back from Longs..)
    The Tutorial Videos on Artsoft just say 'Refer to Figures supplied by machine builder..' Not very helpful..
    Again, I appreciate any assistance..
    You need to use the 'Steps Per' setting in the Mach3 motor tuning pages. this link explains the calculation; http://www.mycncuk.com/threads/7733-...0877#post60877
    It may actually be responding to the G-code but looks like vibration. Edit: sorry just noticed you said no DRO motion, looks like it's not responding to G code then
    To a certain extent, mine sounded like whales singing at first until I got the tuning right.
    Some people say this is normal, I don't know for certain, but mine don't get that hot.
    I was going to suggest that at first but thought you might already have a motor connected to it, yes try that.
    The numbers in the boxes have to match the setup of your machine, the ones in the manual could be correct or they may just be examples.
    Watch these videos to learn about where the numbers come from.
    Lives in Plymouth, United Kingdom. Last Activity: 15 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    Motor heating when "not in use" - steppers aren't quite like other motors. They take power to hold position even when not moving. What the driver will probably let you do (it's often a DIP switch setting) is reduce power to half while the motor is stationary. I think my drivers do this if the motor has been stopped for more than a half-second or so. That might help if you haven't selected this already. Seems normal for steppers to run hot anyway - too hot to touch but not hot enough that a drop of spit sizzles seems ok...
    Thank you for the link, I think I understand this and I shall be able to apply this a little further down the line. For now I just need to know what works (or doesn't) with the Kit I have.
    On the Roadrunner GCode there is only XY&Z DRO.. No 4th motor! I could just un-enable No. 4 perhaps?
    It was always my intention to slave 2 motors for the Y axis and as much as I have seen references to it I can't find any definitive instructions on how it is done.. Any links?
    Re: my final question, that was my thought that the stuff supplied was just a suggestion rather than being specific.. I do feel my problems lie in this area.. understanding the PP Pins and their route..
    I have not heard back from Longs yet.. we shall see..
    Thanks again.
    You can just trace the wires out as shown in the first video
  1. Ok, so whats wrong?
    By Davek0974 in forum 3D Printing Machines
    Last Post: 27-03-2014, 12:19 PM
  2. Looks like the normal first page has gone awry.... or is it my PC?
    By WandrinAndy in forum General Discussion
    Last Post: 03-10-2012, 08:05 PM
  3. Whats It Worth
    By Jay in forum General Discussion
    Last Post: 21-01-2012, 09:08 PM
  4. whats the matter!
    By ptjw7uk in forum General Discussion
    Last Post: 29-11-2009, 07:21 PM
  5. DP of gears, whats it all mean?
    Last Post: 25-10-2009, 11:34 PM
