10-01-2014 #1
I'm using a HTD5 15mm belt to join a big stepper with a shaft, I've used belt / pulley calcs available here:
SDP/SI
I've left 15mm of space on both sides of the stepper, to pull it back a bit and have some tension on the belt. Is that normal practice, or should the pulleys be at precisely the distance shown by the calculator? I'm asking as I've pulled the belt a bit to have less slack on the belt, but after some running, there's tiny bits of rubber under the belt, as if something is rubbing or stressed too far. The belt is not pulled too hard, I'd say it's medium tension, I can still pull it with my finger and it will give slightly. Just wondering if tiny rubbery residue under the belt is normal or not.
Regards,
dsc.
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
Where can i find belt and pulley for a spindle?
By JW1977 in forum Marketplace DiscussionReplies: 5Last Post: 12-11-2013, 08:03 PM -
pulley ratios on 3 pulley axis
By Swarfing in forum Belt Drive, Pulleys & TimingReplies: 35Last Post: 21-07-2011, 12:43 AM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM -
Center Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 21Last Post: 07-04-2010, 02:12 PM
