    I am looking to carve wood with intricate detail down to a depth of 50mm below the top of the stock.
    I can only find ball nose end mills in small diameters with 50mm overall length. Can anyone point to a source of longer small diameter ball nose cutters or perhaps somewhere that could make some custom tooling for me.
    Chris
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 22-05-2023 Has been a member for 9-10 years. Has a total post count of 61. Received thanks 10 times, giving thanks to others 9 times.
    What sort of diameter are you looking for? Wealden Tools do long core box carving bits - the smallest diameter is 4mm.
    Wealden Tool Company Limited Carving Core Box - Long
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 17 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    Have a look here 75mm long, superb cutters to use, not cheep but very very good.
    Beckwith Decor Products
    Phill
    Thanks for the links. Could you explain what a 'core box carving bit' is please and how it differs from other bits.
    I won't know how small I need to go until I experiment. 4mm might do it.
    Chris
    phill05's Avatar
    You don't need core box cutters these are for cutting a half round and are very short, you need the BDP tapered cutters 75 mm long 40 mm cutting length to get down to 50 mm deep,
    BDP001
    B is a 1/16” diameter tapered ballnose with a 1” LOC on a 1/4” shank,3” OAL with 0.0312” radius and 3 degree taper per side Chipload .003 - .005
    Phill
    NB70's Avatar
    Phil is right - of course you wouldn't use the core box cutters on their own. You would use them for shallow finishing passes after you have done the main roughing out with a bigger end mill.
    Nathan
  1. 3d carving oak
    By Mikeb in forum Woodwork Discussion
    Last Post: 24-03-2014, 10:22 AM
  2. V bit carving
    By Mikeb in forum Tool & Tooling Technology
    Last Post: 20-02-2014, 04:52 PM
  3. RFQ: Midlands based, wood carving prototype required (A3 size)
    By lee.hatton in forum Projects, Jobs & Requests
    Last Post: 06-01-2014, 06:05 PM
  4. 3d carving bits
    By drut in forum Tool & Tooling Technology
    Last Post: 04-07-2013, 01:03 AM
  5. BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
    By WandrinAndy in forum DIY Router Build Logs
    Last Post: 05-11-2012, 06:22 PM
