Thread: tools for 3d wood carving
17-01-2014 #1
I am looking to carve wood with intricate detail down to a depth of 50mm below the top of the stock.
I can only find ball nose end mills in small diameters with 50mm overall length. Can anyone point to a source of longer small diameter ball nose cutters or perhaps somewhere that could make some custom tooling for me.
Chris
17-01-2014 #2
What sort of diameter are you looking for? Wealden Tools do long core box carving bits - the smallest diameter is 4mm.
Wealden Tool Company Limited Carving Core Box - Long
17-01-2014 #3
Have a look here 75mm long, superb cutters to use, not cheep but very very good.
Beckwith Decor Products
Phill
17-01-2014 #4
Thanks for the links. Could you explain what a 'core box carving bit' is please and how it differs from other bits.
I won't know how small I need to go until I experiment. 4mm might do it.
Chris
17-01-2014 #5
You don't need core box cutters these are for cutting a half round and are very short, you need the BDP tapered cutters 75 mm long 40 mm cutting length to get down to 50 mm deep,
BDP001B is a 1/16” diameter tapered ballnose with a 1” LOC on a 1/4” shank,3” OAL with 0.0312” radius and 3 degree taper per side Chipload .003 - .005
Phill
18-01-2014 #6
Phil is right - of course you wouldn't use the core box cutters on their own. You would use them for shallow finishing passes after you have done the main roughing out with a bigger end mill.
Nathan
3d carving oak
By Mikeb in forum Woodwork DiscussionReplies: 11Last Post: 24-03-2014, 10:22 AM -
V bit carving
By Mikeb in forum Tool & Tooling TechnologyReplies: 4Last Post: 20-02-2014, 04:52 PM -
RFQ: Midlands based, wood carving prototype required (A3 size)
By lee.hatton in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2014, 06:05 PM -
3d carving bits
By drut in forum Tool & Tooling TechnologyReplies: 9Last Post: 04-07-2013, 01:03 AM -
BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
By WandrinAndy in forum DIY Router Build LogsReplies: 54Last Post: 05-11-2012, 06:22 PM
