    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 3 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Using Cambam and Mach3.
    After writing a program in Cambam with different tool sizes, then continuing to Mach3, the machine doesn't stop to let me manually change tools. I unchecked the "ignore tool change" in Mach3 but no difference.
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    What do you mean unchecked the ignore tool change?
    It's a button list in the General Config... where you can select Ignore Tool Change, Stop Spindle Wait for Cycle Start, or AutoTool Changer (which then invokes the tool change scripts).
    dudz's Avatar
    Ok Thanks, I tend to forget stuff like this !
    Another thing I am getting problems with ; I design a job in Cambam with a cutting pass of 1.5mm. Then in mach3 I set the zero in Z axis and start the Job. The Z plunges straight through my material much more than 1.5mm.... like it completely ignores the data in cambam. This doesn't happen all the time, but quite often.
    Have you checked to see if the produced G-Code has the correct Z depth?
    dudz's Avatar
    Yes. I sorted now. Its something to do with offsets . Its strange because I haven't used anything other that G54 for ages. Anyway, I went though it all and managed to correct it.
    Offsets should have nothing to do with tool changes being ignored.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    dudz's Avatar
    No it hasn't, well done lol
  1. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  2. did you change something?
    By wilfy in forum General Discussion
    Last Post: 29-12-2012, 10:58 PM
  3. how to change a clip art
    By luke11cnc in forum Computer Software
    Last Post: 03-12-2011, 12:47 PM
  4. XYZ Centurian 450 VMC tools sticking during tool change (M06)
    By craftydonkey in forum Milling Machines, Builds & Conversions
    Last Post: 19-10-2011, 03:11 PM
  5. WANTED: Tool holders for T2 (I think) quick change toolpost
    By Jonathan in forum Items Wanted
    Last Post: 07-05-2011, 10:30 AM
