  1. I just measured the TiR on my Kress 1050, and it is around 0,04mm.
    This seems a bit high, is there anything you could do to improve it? I would guess this TIR is one of the reasons I have problems getting clean cuts in brass. (CZ120)
    I am considering upgrading to a better spindle, does anyone have suggestions for moving up a notch?
    The eBay watercooled "Chinese spindles" seems to be quite a gamble, I would prefer a spindle with a warranty that counts for something.
    Regards,
    Hauk
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    I worried about the same thing and ended up buying a Chinese spindle plus VFD but from a UK supplier. Cost more than eBay but good service and a voice that speaks the right language on the end of a phone. I went to cnc4you and don't regret it.
  3. Quote Originally Posted by Neale View Post
    Have you measured TIR on the CS? It is claimed that they should be better than 0,005mm.
    I am also curious about what experiences you or anyone else have with cutting brass using a fairly light router and a Chinese Spindle.
    Regards, Hauk
    Just had a chance to measure TIR on my spindle. My best dial gauge only reads down to 0.01mm, and as far as I can judge, TIR on my spindle is slightly over 0.01mm. Difficult to be very accurate as the CNC router is built from MDF and there's a lot of play and bend in the structure, so every time you touch the spindle collet to rotate it, you see more movement than that! I measured using the shank of a solid carbide cutter in a 6mm ER20 collet just below the collet face, so runout further down could be more. The collet was from Arc Euro Trade, not the 1/4" collet supplied with the spindle, and I can't see any figures quoted for collet accuracy.
  1. Cut depths and spindal speeds to improve finsh time
    By Fivetide in forum Tool & Tooling Technology
    Last Post: 21-05-2015, 08:39 AM
  2. trying to improve my board game
    By cubikoman in forum General Discussion
    Last Post: 12-05-2012, 06:57 AM
  3. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  4. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
  5. NEW MEMBER: cubikoman needs to improve quality of his boardgame
    By cubikoman in forum New Member Introductions
    Last Post: 16-02-2011, 12:17 PM
