20-02-2014 #1
I got a bigger Nema 34 motor recently and ordered a pulley from BeltingOnline to match the shaft on the motor. Tried it out yesterday and the keyway on the motor shaft seems to be cut at an angle, see photo below. This in turn causes the pulley to get stuck as the key sits at an angle. Pulley fits fine on the shaft with no key, also the key fits nicely in the pulley keyway. Put all things together and it's stuck.
Any ideas on how to fix this with no heavy machinery?
Regards,
T.
20-02-2014 #2
20-02-2014 #3
21-02-2014 #4
I'll swap the motor and hopefully get a properly cut one. The misalignment is pretty severe, so filing it down would be a long process, especially with the keyway being awkward to work on and the material being hardened steel (or whatever the shaft is made of).
Regards,
dsc.
21-02-2014 #5
I would say that the key way on the pulley is out of line and not the motor, just get a file to it.
22-02-2014 #6
Motor shafts turn & mill fairly freely, I had to reduce a 3/4 Hp 3 Phase motor shaft size to keep my mill internals standard when upgrading it, I think you'll find a file or even Dremel with a bur will do the job nicely, the pulley should file easily and as Swarfing said appears to be the location of the problem,
Regards,
Nick
22-02-2014 #7
22-02-2014 #8
If you import the image into Sketchup as a texture then draw some lines extending from the keyway sides, it appears both shaft and pulley are out.
Edit: Tom, you must have had the same idea at the same timeLast edited by EddyCurrent; 22-02-2014 at 01:02 PM.
22-02-2014 #9
25-02-2014 #10
Just a quick update to praise Gary / Steve (Zapp), not only did they collect the motor for inspection, they also went through the trouble of making sure the pulley fits properly (re-broached it) before sending the whole lot back. Proper customer service and beyond.
If you are reading this, cheers guys.
Regards,
T.
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
16 tooth pulley HTD5 15mm on a 14mm shaft
By dsc in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 07-06-2013, 11:51 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Pulley kit to step up a stepper RPM
By HankMcSpank in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 11-07-2009, 09:49 PM
