Thread: Seig KX1 CNC Milling Machine
02-03-2014 #1
Hello I am selling our Seig KX1 milling machine, it's approximately two years old and has been used in the main for engraving brass and aluminium along with machining small parts in aluminium and engineering plastics. It is an excellent machine and we have now moved onto a slightly bigger machine and the space is needed so this little machine needs to go. The KX1 is in excellent condition and will come complete with a MT2 collet chuck and set of collets. You will need a Mach 3 license and compatible PC to operate this machine. Please contact me for further details.
£1500.00 ono.
Specification:
End Milling Capacity 10mm Face Milling Capacity 20mm Drilling Capacity 10mm Effective Table Size 400x145mm Lubrication Press Button Oilers Table Travel - X-Axis 260mm Table Travel - Y-Axis 115mm Head Travel - Z-Axis 185mm Head-Table Distance 70-255mm Ballscrew Size (Dia. x Pitch) 12mm x 4mm X-Axis Motor 1.35Nm Y-Axis Motor 1.35Nm Z-Axis Motor 2.2Nm Throat 140mm No. of T-Slots (Size) 3 (8mm) Positional Accuracy 0.01mm Spindle Taper MT2 Spindle Motor 500w Brushless DC Motor Spindle Speed 250-7000rpm Max. Spindle Motor Torque 1.8Nm @ 1500rpm Power Requirements 230v AC 50Hz Overall Dimensions (w/d/h) 630x630x630mm Max. Space Required (w/d/h) 910x630x730mm Shipping Dimensions 76x76x79cms Weight (Net/Gross) 86/120kg
***PLEASE NOTE THAT THIS IS NOW SOLD, THANK YOU***Last edited by D2C; 17-03-2014 at 01:14 PM. Reason: Item SOLD
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
Seig C4 Lathe CNC conversion
By njhussey in forum Sieg LathesReplies: 1Last Post: 11-04-2014, 06:40 PM -
seig x3 R8 V MT3
By dazza in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-02-2014, 01:14 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
