    It's fair to say I come from the 'brick shithouse school of engineering' and so when I look at this ball nut bracket I start to wonder.
    Ball Nut Mount/Bracket Nut Mount For 1605 1604 1610 16mm Ball Screw CNC Router | eBay
    I'm going to use it for the Z axis front plate and weighing the assembly it comes to just over 14kg, that's with the spindle motor attached. As you can see the bracket is fastened to the front plate with 4 x 5mm studs, now my question is, does that strike you as being strong enough ? it's only shear forces involved I think and I can't cut a recess in the front plate that it could sit in.
    I could tap it to 6mm but then there is less 'meat' left on the bracket itself around the holes.
  1. WANTED: Ball nut brackets for16mm ballscrews
    By EddyCurrent in forum Items Wanted
    Last Post: 07-02-2014, 12:47 PM
  2. RFQ: 2 x Gantry Mounting Brackets Needed
    By Washout in forum Projects, Jobs & Requests
    Last Post: 27-11-2012, 07:34 PM
  3. 2 cubes in ball and more
    By mutka in forum Metalwork Project Showcase
    Last Post: 30-07-2012, 09:26 PM
  4. RFQ: Cnc or laser cut steel brackets
    By don_jarr in forum Projects, Jobs & Requests
    Last Post: 12-04-2012, 09:23 PM
  5. WANTED: Bridgeport x and y bearing brackets
    By Philmollatt in forum Items Wanted
    Last Post: 10-10-2009, 03:22 AM
