    Came across this from Igus, looks interesting, no lubrication plus other benefits, could be an alternative to China ball screws etc. but is it any good ?
    That should be good in a perfectly clean, dry environment.
    - Nick
    Our work uses the plain linear bearings, they require a bore to the correct tolerance to ensure the internal bore of the bush is to correct size after it is squeezed in.
    I would still use a ball bearing type on a round rail having used both.
    You'd want to use the anti backlash version.
    igus® drylin® - Anti Backlash nuts
    They should work fine, as there are hundreds of builders at CNC Zone using plastic nuts on acme screws, including myself.
    3 things to be aware of.
    1) They typically aren't rated nearly as high for loading as a ballscrew. With an anti-backlash plastic nut, if you exceed the load rating, then you may see some backlash.
    2) Even though they claim no lubrication is needed, they will work better with lubrication. I use pneumatic tool oil on mine.
    3) Depending on the screw, they are probably somewhere between 50%-80% efficient. Compared to a ballscrew that is about 95% efficient. SO you typically lose~30% of your motor power to frictional losses.
    **EDIT** I hadn't watched the video prior to posting. It appears that their special thread profile increases the efficiency But I still doubt that it's better than 80%, but I'll have to look into it. I wouldn't be surprised if these are more expensive than ballscrews from China. ** End EDIT**
    Having said that, I'll be using plastic nuts and acme screws on the Z axis of the new machine I'm building. Mainly, because they are far more compact than a ballscrew and nut. And The homemade plastic nut on my current machine's Z axis has been working fine for over 5 years.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    goodbye123
    As ger21 says, these work fine on acme. Jump over to cnc zone and look up the "evanut". It's a cool easy way to make nuts. Just made 2 for my xy table and they lowered my torque an eliminated backlash for bout 2 bucks. There is conjecture on how they would work on a ball screw screw, why don't you try it and let us all know
    dave
  1. Laminate plastic help!
    By totts in forum Marketplace Discussion
    Last Post: 13-04-2013, 07:14 PM
  2. Some kind of plastic needed
    By m_c in forum General Discussion
    Last Post: 08-04-2013, 12:29 PM
  3. RFQ: Small parts from FR4 plastic - help!
    By James in forum Projects, Jobs & Requests
    Last Post: 12-06-2012, 04:02 PM
  4. 2 ply plastic help
    By h4ppy-chris in forum General Discussion
    Last Post: 30-01-2011, 04:54 PM
  5. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
