27-03-2014 #1
ive been looking for a uk supplier for coloured acetal or delrin plate... red.. green blue.. etc
preferably an online shop and not someone I have to email for a price..wait for a reply..if any one could recommend a place,thanks ;)
18-04-2014 #2
Hi, I was looking for coloured acetal myself a while ago, the best place I found was plastics4u.co.uk, only had black or white acetal in stock but they said if the order is big enough, other colours can be produced. ....hope this helps....good luck
18-04-2014 #3
This is the place I've used. If the type of plastic is not so important then you can get a wider selection of colours. There may be somewhere cheaper now, no idea...
18-04-2014 #4
thanks both.
jon that's where I get my acetal from,am not keen on moving from acetal/delrin and would need to be 20mm thick plate,i just fancied knocking up a few parts I make in other colours,there seems to be more options out there for round bar.
25-05-2014 #5
That's a interesting Link Jonathan I'm interested in the Tufnol can this item be tapped to use as a bed ?
James
26-05-2014 #6
Yes, I think so, but if you compare the price of Tufnol from that site to aluminium in reasonable quantities, then it's only about 20-25% cheaper than aluminium so I'd stick with the latter. One not so obvious advantage of using aluminium for the bed is if the part is clamped directly to the bed, the aluminium will conduct the heat out of it quite well - not the case for plastics.
RFQ: RFQ.. Acetal or acrylic... laser cut or routed.
By purpose in forum Projects, Jobs & RequestsReplies: 2Last Post: 12-12-2013, 12:03 PM -
RFQ: Acetal parts needed
By dazza in forum Projects, Jobs & RequestsReplies: 3Last Post: 02-11-2013, 04:59 PM -
looking for acetal pellets /granules
By dazza in forum Marketplace DiscussionReplies: 0Last Post: 31-03-2013, 11:35 AM -
Delrin & Nylon S & F please
By craigrobbo in forum Machine DiscussionReplies: 2Last Post: 21-07-2012, 12:19 PM -
RFQ: Delrin drive nut (lee)
By progomez in forum Projects, Jobs & RequestsReplies: 29Last Post: 14-10-2009, 10:00 PM
