Has anyone here fitted a Proma THC to a Plasma running Mach3??
I have one coming and am trying to find examples of working setups.
I can only use the torch up and down signals as I only have two inputs left on my breakout board.
Hopefully it will work.
11-04-2014 #2
Well i've totally reconfigured my machine and now have the UP, DOWN and ARC-OK signals coming in to Mach3 OK. In the end I switched to G28.1 height setting which freed up the input used by the probe.
However I cannot get the THC on/off button on Mach3 to do anything ( and yes it is a licensed copy)
If the "Allow THC inputs when not in THC mode" box is ticked, It will work but i cannot stop it, if it is unticked it will not work at all regardless if the THC button is on or off.
Any ideas??
14-04-2014 #3
Never mind, it's all working - the THC on/off button does nothing unless you are running code, it will not allow the up and down signals through at all without a program running AND the arc-ok signal AND the THC on/off button being set to on.
Torch Height control
By Bobp in forum General ElectronicsReplies: 21Last Post: 09-12-2019, 04:46 PM -
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 29-04-2014, 12:36 PM -
RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-03-2014, 07:56 PM -
Proma THC with Mach3
By gerrymoore in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 25-04-2013, 12:44 PM
