Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. #41
    Fit a hand crank to the rear stub shaft of the stepper motor.
    That works on so many levels, a complete solution, I am truly in awe
  2. #42
    Lives in Plymouth, United Kingdom. Last Activity: 8 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    Almost, but not quite. It just needs a solenoid-operated lever to give the user a slap on the wrist when the limit switch is triggered.
  3. #43
    Like me you are forgetting Gotama's advice to Siddhartha... "Beware of too much cleverness".
  4. #44
    When I was about 20 years old my work colleagues presented me with the (fictitious) Duke of Edinburgh Award for 'Use of Stone Age Tools'.
  5. #45
    Or, when the handle stops turning, you've hit the end stops.
  6. OK, here's version 0.1 for discussion....
  7. #47
    Tbh my approach just generates n pulses for each wheel pulse at a rate that's fast enough to finish before the next wheel pulse.
    As touched upon earlier, the 'jitter' this adds to the pulse stream will reduce the maximum feedrate somewhat as the motors wont run as smoothly. How much is hard to say, but it could be a problem...
    Direction required?
  8. #48
    More and more it looks to me that the best approach is a mechanical step-up! Trying to multiply the number of pulses electronically is inherently the wrong way to go.
  9. #49
    Fix the mpg down on a board and mount a larger mdf wheel next to it on an improvised pivot. Use a wide rubber band as a belt . Should be relatively easy to get a 5:1 step up.
  10. #50
    Quote Originally Posted by JohnHaine View Post
    Better still, connect the rubber band to the stepper motor to get a closed loop system. I'm sure you'd get positive feedback for that idea ;)
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 04:41 PM
  3. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  4. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
