Thread: 2.5d Probing
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Going to take this discussion/build to a forum that doesn't continually play with site settings.
    This might be useful.
    Probe-It! Mach3 Wizard | Crafty CNC
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Thanks for that Gerry, it looks pretty much ideal for what I'm aiming to do.
    I just need something suitable running Mach3 now, as my only currently functioning mill does't run Mach!
    First - I know this is an old thread, but it says what I want to do.
    I need to do a contour map of an object and reproduce it in wood. It does not have to be accurate to the angstrom. I am trying to make a wooden insole for a shoe, so a 'bed of nails' digitisation would be OK and probably a 2mm grid would be fine enough.
    I would start with a plaster cast of the foot and then 'scan' it, before putting it through software to end up with Gcode.
    My probe is yet to be made, but I have about 20 4mm square 'pills' of QTC (Quantum Tunnelling Compound) and one of them could make a Z axis probe switch.
    So I am relying on the forum to give me some ideas, is there any bolt-on software to Mach3? (does Probe-it fit the bill or is there anything better on my virtually zero budget?).
    Help please
    Probe-It is ideal for contouring, but it doesn't really do Z digitising other than for basic probing for establishing heights.
    If a bed of nails approach would work for you, then Mach already has a free bed of nails digitising wizard included.
  6. The Following User Says Thank You to m_c For This Useful Post:
  7. #6
    It just demonstrates to me what a narrow subset of knowledge I have about Mach3. I will investigate today. Thanks m_c.
  8. #7
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 22 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    I don't know if this would help you but I take an image of an item within a known size box or put a ruler in the shot, save in grey scale import it into Vetric Aspire and produce a 3d map you can also produce vector outline's of the imprint to clean up the imprint, save as STL file create the toolpaths save as G-code and away you go.
    But as plaster is white you might have to colour the imprint a little to get best results.
    Phill
  9. #8
    Phill
    Thanks Phill, but I don't have Vectric Aspire, and as I am only a 'poor old pensioner' It is out of my budget. If I were using a non-contact digitising method, then I would use alginate to make the cast.
  1. probing on all metal machine
    By routercnc in forum General Electronics
    Last Post: 23-03-2020, 04:59 PM
  2. PCB probing information software
    By Daedelus in forum Computer Software
    Last Post: 31-03-2013, 09:28 PM
  3. Probing / Digitizing - What the best way to do this job?
    By Mad Professor in forum Probing, Digitizing & Scaning
    Last Post: 08-05-2011, 12:32 PM
