04-01-2021 #11
Dean
I use only good quality digital drivers like Leadshine EM503 and CSMIO/IP-M controller.
I agree some driver can't cope with accuracy and repeatability.
For example this heap DM542
cost 23% price of Leadshine EM503
with exactly same parameters.
I personally tested both drivers under same travel speed for torque value.
Motor 8 leads connected parallel (low inductance and higher torque @ higher speed)
Results:
Cheap driver was stalling with much less speed and can't hold same torque - hence the price difference.
My observation regards torque drops vs micro stepping were not according to what I knew from data.
I disregards motors tested on bench - only connected to the machine via 5M HTD belt and spindle not running.
There are few YT clip showing same experiment. I found 16MS 3200 will not drop torque to ~10% of nominal
I think driver send more current to winding when micro-steps are used hence motor can lift much more than 10% of theoretical value.
Will try to make video when get proper torque gauge display or mini scaleLast edited by Tom J; 04-01-2021 at 02:40 PM.
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Setting up stepper motor drivers
By croy in forum Motor Drivers & ControllersReplies: 25Last Post: 30-09-2012, 09:51 PM -
eBay Stepper Motor Drivers from China
By Mad Professor in forum General ElectronicsReplies: 6Last Post: 20-07-2009, 10:54 PM
