    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 5 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Ok. I can mill 2D objects no probs.
    I wanted to mill a simple semi circle slot along the horizontal plain of the material. The circular slot is to be 120mm long / 11.113mm deep
    This picture is just an example I made so you can see what I am trying to do. I have milled the object all apart from the slot on the left.
    What is the simplest way to do this ?. I have today tried to create a 3D version in FreeCAD software, but when imported to Cambam, I have no Idea what to do with it. Especialy as I only want the slot. Maybe there is a way in Cambam, that lets me do this without getting into 3D ?
  2. whats the radius of the slot? or is it a true semicircle so diameter = 22.226mm (spurious level of accuracy aside), or 7/8". Maybe you can find a 7/8" ball nose cutter.
  3. The Following User Says Thank You to irving2008 For This Useful Post:
    dudz's Avatar
    Hi irving,
    The Dia is 7/8" . I have 6mm ball nose cutters. I can't fathom out how to cut a semi circle slot. Cambam just creates a rectangular pocket. Obviously I am missing a vital bit of info. My DOC is only 1.5mm in aluminium
    whats the radius of the slot? or is it a true semicircle so radius = 11.113mm (spurious level of accuracy aside), or 7/16". Maybe you can find a 7/16" ball nose cutter, like this one (scroll down 1/2 way)
  5. Edited my post, but not quickly enough.. got my radii and diameters confused (its the heat). Don't think cambam can do that. If you can find a 7/8 cutter and get it in your spindle the doc isn't an issue, just go round and round.
    Hi irving,
    The full circle would be 7/8". I have 6mm ball nose cutters. I can't fathom out how to cut a semi circle slot. Cambam just creates a rectangular pocket. Obviously I am missing a vital bit of info. My DOC is only 1.5mm in aluminium
  6. #5
    dudz's Avatar
    Hhhmm chinese spindle. I dont know if the speed will cope too low with such a large endmill . If Cambam wont do it, what software will ?
    Or maybe something inside Mach3 ??
  7. #6
    But you aren't trying to cut a semi-circular slot, you are trying to cut a semi-circular slot with something at the ends so the software knows what to do when it gets there. The tool needs to know where it can overhang.
    Given half a chance any self respecting software will not view this as a pocket sinking exercise. That way it can cut the outline when it reaches the end. Simples.
    The easiest way is to write a quick program that spits out a G code, that way you can be sure you get a finishing cut that increments to the face rather than the depth.
  8. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  9. #7
    dudz's Avatar
    OK thx.
    I just tryed the trial version of Meshcam. It was simple to do (on the pc)
    Pitty I cant get Cambam to do it though.
  10. #8
    OK thx.
    Have you tried the CamBam forum? There are some very knowledgeable people on there.
  11. #9
    I would draw the slot as a line longer than you need draw a semi-circle to the size you want and extrude the semi C along the line, create your tool path using a bull-nosed cutter, using center line of where you want to put slot across the part, use this as XYZ = 0 set your cutter & g-code to run from there, it should cut a semi-circle across the part.
    Phill
  12. #10
    dudz's Avatar
    Phill
    This is the bit, Im not sure how to do ?
  1. Setting rapids in CamBam
    By swisscheese in forum CAD & CAM Software
    Last Post: 04-04-2014, 02:30 PM
  2. Mach3 / cambam
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2013, 06:02 PM
  3. Cambam / milling Alu
    By dudz in forum CAD & CAM Software
    Last Post: 23-12-2012, 05:22 PM
  4. Drilling Acrylic with CamBam
    By m.marino in forum Machine Discussion
    Last Post: 06-06-2012, 04:45 PM
  5. How do i make this in cambam?
    By motoxy in forum CAD & CAM Software
    Last Post: 09-02-2012, 06:01 PM
