Thread: Joining elastic bungee cord.
I have a plywood product im thinking about producing on my router. It incorperates a bungee cord that acts as a preload spring.
I need to join 3mm elastic shock cord into a loop to make the part. Would rather not simply tie them together as its hard to get the lengths consistant and it looks a little messy.
These crimps look quite good, I contacted the seller in regards to which type of crimping pliers would work for this, but they are taking their time to reply. I can't find anything similer in the UK. What would you guys do to join bungee cord in neat loop?
Here is the link to the crimps
https://www.etsy.com/uk/listing/1555...ver?ref=market
GavCNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
14-10-2014 #2
Best would be if you join then via small hot melt casting. The way a USB or 3mm jack cable ends. You can use good high temp heat glue gun/190-220C/, make small 2 piece aluminum mold and inject the hot melt - Polyamide Sticks - TEC Bond 7718 , thats what i use.
Dont forget to leave small air escape hole/0.5mm or similar/ and use 2 pins to center the mold. Or maybe not, the air will escape through the bungee cord
I have done that and works, i have cast things as big as wheel over 2 skate bearings using 80W gun. You will find a good ~200w gun extremely easy to work with
There are other sizes, you have to calculate if its worth but 12mm works ok for small details. Otherwise i would jump to bulk melt gun
Guns 12mm :
https://www.gluegunsdirect.com/shop/...12mm-glue-guns
Glue 12mm:
https://www.gluegunsdirect.com/shop/...ecbond-7718-12
PS:
or sth like these:
http://www.aliexpress.com/item/Whole...111629169.html
http://www.ebay.co.uk/itm/Blind-cord...58665590&rt=ncLast edited by Boyan Silyavski; 14-10-2014 at 09:23 AM.
14-10-2014 #3
Those crimps look like a cheap, neat, way to do it. I'd be surprised if you couldn't do the job with a big pair of pliers, or for a posher job drill a hole in a bit of steel, slit it down the middle, and clamp in vice as an improvised press. Look for a "proper" tool if the prototypes work out well!
Joining or "but joining" linear rails
By CNCBlug in forum Rails, Guideways & BearingsReplies: 5Last Post: 09-10-2014, 08:56 AM -
T and L profile Joining plates
By dudz in forum Marketplace DiscussionReplies: 2Last Post: 02-01-2013, 08:58 PM -
NEW MEMBER: Finally got round to joining the best CNC group on the net!!!
By g4ghp in forum New Member IntroductionsReplies: 13Last Post: 19-03-2012, 07:31 PM -
NEW MEMBER: Hello Im interested in joining you all
By Guisborough in forum New Member IntroductionsReplies: 3Last Post: 18-08-2010, 11:01 PM -
NEW MEMBER: Joining the "ship"
By Ali Kat in forum New Member IntroductionsReplies: 2Last Post: 13-08-2007, 08:49 AM
