    Hey guys can anyone tell me the difference between the mod1&2 rack? is it just the case of the teeth being spaced different?
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    Tooth size.
    MOD is metric tooth size, DP is imperial tooth size.
    MOD the bigger the number, the bigger the teeth.
  4. Mod is short for Module (metric module in this case)
    Quote Originally Posted by http://en.wikipedia.org/wiki/Gear#The_module_system
    The module system
    Countries which have adopted the metric system generally use the module system. As a result, the term module is usually understood to mean the pitch diameter in millimeters divided by the number of teeth. When the module is based upon inch measurements, it is known as the English module to avoid confusion with the metric module. Module is a direct dimension, whereas diametral pitch is an inverse dimension (like "threads per inch"). Thus, if the pitch diameter of a gear is 40 mm and the number of teeth 20, the module is 2, which means that there are 2 mm of pitch diameter for each tooth.[21]
  5. The Following User Says Thank You to BillTodd For This Useful Post:
  1. Rack & Pinion Gearbox/Gearing
    By andrewbond in forum Rack & Pinion Systems
    Last Post: 12-09-2015, 09:10 AM
  2. BUILD LOG: 10ft x 5ft Rack & Pinion, BIG BUILD
    By andrewbond in forum DIY Router Build Logs
    Last Post: 03-03-2014, 09:20 PM
  3. z axis rack and pinion advice
    By marbles in forum Gantry/Router Machines & Building
    Last Post: 09-01-2013, 11:41 PM
  4. Rack and Pinion
    By pmcb1011 in forum Rack & Pinion Systems
    Last Post: 31-05-2011, 11:55 AM
  5. Headsup for the Hemsworthlad! Rack and Pinion
    By Smiler in forum Rack & Pinion Systems
    Last Post: 14-06-2009, 11:36 PM
