Thread: Vcarve workpiece orientation
30-10-2014 #31
30-10-2014 #32
What if you're v-carving a rectangular workpiece? Rotating the vectors only will give you a very different finished workpiece.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
30-10-2014 #33
30-10-2014 #34
Okay, this is my last post on this. I do not seem to think you can rotate the material. All I'm saying is two things;
1. Only the vectors rotate when you apply transforms, the material does not.
2. As I see it the material is part of the workpiece
And lastly I don't have any problem with this, it's just the way it is.Last edited by EddyCurrent; 30-10-2014 at 10:17 PM.
30-10-2014 #35
31-10-2014 #36
I lied
phill05, if I was cutting shapes from sheet material or stock that was well oversize for the job, it would not matter that only the vectors rotate.
But if you cut like I do where the material profile is cut to size first on a saw, then clearly if only the vectors rotate they would no longer fit the stock material.
I use CamBam mostly and it's the same with that, if I apply transforms the stock material is unaffected, so what I have to do is resize the stock to orient it in the other direction, i.e. swap over the X and Y values.
Now all that is fine and I don't have a problem with that but what I am saying different to you is this, the material or stock in some instances, as above, is clearly the workpiece.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
31-10-2014 #37
Eddy the question asked was how do I create my workpiece Vertically in VCP to which I replied, change workpiece orintation.
Eddy It was your contribution that first saw light of Material: "I just tried Ctrl +9 45 left, Ctrl +0 45 right in VCarve, it rotates the vectors but not the material (workpiece stock)"
Eddy I am working on different designs every day of many differnt sizes and the Vectors are my workpiece, I don't get to see a machine bed or get my hands dirty, I design and feed G code to 2 machines, I tell the guys 30 plus miles away from me in which axis to load the stone, power on and leave me to it.
So could we both agree / disagree the we could both be right.
Last question to D-man great you got sorted mate lets see some of your work now, and who looks the fussy twat now.
Phill
31-10-2014 #38
No
post #17, Earl said your hotkeys in post #15 only rotated the vectors not the workpiece
post #20, you said, "The Vectors are the workpiece!!"
post #24, I was responding to your post#20 by confirming what Earl said in post #17.
Then I started to think about what constituted the 'Workpiece', it was different to your thoughts, and it went on from there
And that explains how you visualise the workpiece.
In the greater scheme of things it does not matter who thinks what, but I generally like to find a difinitive answer such as the definition of 'workpiece'
Maybe this ? http://www.oxforddictionaries.com/de...lish/workpieceLast edited by EddyCurrent; 31-10-2014 at 03:03 PM.
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
Workpiece illumination
By cropwell in forum Workshop & EquipmentReplies: 0Last Post: 29-09-2013, 10:21 PM -
Securing the workpiece
By jrob3rts in forum Machine DiscussionReplies: 3Last Post: 16-06-2012, 10:21 PM -
Vcarve to Mach3
By jcb121 in forum VectricReplies: 6Last Post: 01-04-2012, 05:21 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM
