02-11-2014 #2
yeah cheers guys, feel like a pro now when im setting up haha
02-11-2014 #3
Glad to see you've got it working and understand the parameters now.
Seeing as you're new to probing, here are a few tips that might help you..
Assuming that your setting your jobs up with z0 being the top of your workpiece :
When cutting pockets, slots or engraving/v-carving do as you're doing now - put the touchplate on top of the workpiece and zero to top. This means your cuts will be the exact depth that you've programmed.
When cutting profiles (full depth of your material) then put your touchplate on your spoilboard (probably upside-down in your case as you have a lip on the bottom) and zero to the spoilboard. THEN, click in the Z axis DRO and SUBTRACT the thickness of your workpiece material from whatever the DRO is showing. ie. if the DRO shows 30.000mm and your material thickness is 10mm change the Z DRO to value to 20.000mm.
The reason for doing this is that your workpiece may not be exactly the thickness you think it is. For example, I recently bought some 18mm thick plywood from B&Q. It turned out that it actually measured 15.5mm thick. I'd programmed my toolpaths based on the material being 18mm. If i'd probed to the top of the material then I would have ended up cutting 2.5mm into my spoilboard - and the 2mm tabs i'd programmed to prevent the part breaking free wouldn't have worked. Probing to the spoilboard meant that my spoilboard wasn't damaged and the tabs worked. It also means that if your material is slightly thicker then you'll still cut all the way through rather than leaving an onion-skin.
I use a similar method for surfacing my spoilboard too. I have a toolpath created to surface my spoilboard which has a cutting depth of zero. To use the file, i'll probe to my spoilboard as above, then click the Z-DRO and ADD the amount that I wish to take off the spoilboard. ie, if my Z DRO is showing 30.000mm then i'll change it to 30.200mm. This will take 0.2mm off the spoilboard and means I can have one 'surfacing' gcode file which can be changed on-the-fly to remove as much or little material as I want.
I hope I haven't confused you even more, but these procedures work for me and might help someone else reading this thread.
Si.
The Following User Says Thank You to firetrappe For This Useful Post:
02-11-2014 #4When cutting profiles (full depth of your material) then put your touchplate on your spoilboard (probably upside-down in your case as you have a lip on the bottom) and zero to the spoilboard. THEN, click in the Z axis DRO and SUBTRACT the thickness of your workpiece material from whatever the DRO is showing. ie. if the DRO shows 30.000mm and your material thickness is 10mm change the Z DRO to value to 20.000mm.
Just set the Material Offset to 18, and zero to the spoilboard, and your Z zero will be set 18mm above the spoilboard. No need to be changing DRO values. The screenset can handle this automatically.
I use a similar method for surfacing my spoilboard too. I have a toolpath created to surface my spoilboard which has a cutting depth of zero. To use the file, i'll probe to my spoilboard as above, then click the Z-DRO and ADD the amount that I wish to take off the spoilboard. ie, if my Z DRO is showing 30.000mm then i'll change it to 30.200mm. This will take 0.2mm off the spoilboard and means I can have one 'surfacing' gcode file which can be changed on-the-fly to remove as much or little material as I want.Last edited by Ger21; 02-11-2014 at 03:08 PM.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
02-11-2014 #5
Gerry, thanks for the clarification of the Material Offset parameter. I did use that originally but found that I sometimes forgot to change it as I always have the 'Run' tab showing. I find it easier to remember to change the DRO but that's just my personal preference.
Si.
02-11-2014 #6
I almost added the statement that the only problem with the Material Offset, is forgetting that it's on or off.
Gerry
Torch Height control
By Bobp in forum General ElectronicsReplies: 21Last Post: 09-12-2019, 04:46 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
1/4" / 6mm edge finder?
By jcb121 in forum Marketplace DiscussionReplies: 0Last Post: 18-03-2013, 02:58 PM -
Driver wiring to my computer for mach3 to control
By AdCNC in forum Motor Drivers & ControllersReplies: 13Last Post: 01-04-2010, 12:27 AM -
Electronic edge finder: how do they work?
By irving2008 in forum Probing, Digitizing & ScaningReplies: 14Last Post: 29-08-2009, 10:25 PM
