Thread: Halifax 10" lathe
06-12-2014 #11
Ross just re-reading and see you say rear "bearing slides" I cannot see how pre-load can be done without this bearing sliding, I cannot get this off even with puller as only place to get puller is outer race so don't want to put to much force on it. I'm thinking using a press but this would be forcing against plastic pulley with the force being applied on the damaged (threaded) end of spindle can you see any problems as I don't want to damage pulley.
just read thro your repair post. What happened to the chap (bogstandard) you was communicating with?Last edited by i lunn; 06-12-2014 at 02:11 PM.
06-12-2014 #12
The inner race slides on the shaft to apply the preload. It is a very tight fit and over time can get worse.
It was a while ago that I did mine and cant remember every step. I seem to recall you take all the lock pins and keys out off the pullies and then slide them to one end to give you space to get at the bearing. The outter race can be moved back as well so you can get the puller on the inner race. Might be worth protecting the end.
If it wont move then try a little heat to break the bond or leave in an oil bath for a day or two.
I got your pm but not had chance to go to the workshop yet.
As for bog's I don't know, haven't been on here for a while myself. He sure would be the best one to help you tho.
NEW MEMBER: Hello from Halifax !!
By malzyk in forum New Member IntroductionsReplies: 0Last Post: 07-09-2013, 02:26 PM -
WANTED: 5" / 125mm Lathe chuck
By Jonathan in forum Items WantedReplies: 2Last Post: 21-02-2012, 01:22 AM -
FOR SALE: Southbend 13" lathe
By Swarfing in forum Items For SaleReplies: 5Last Post: 27-11-2011, 10:54 AM -
Repairing Atlas 10" lathe
By Ross77 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 57Last Post: 18-07-2010, 02:10 AM -
FOR SALE: My old Southbend 415 9" lathe is now on ebay
By BillTodd in forum Items For SaleReplies: 0Last Post: 04-09-2009, 09:25 PM
