Page 2 of 2 FirstFirst 12
    Quote Originally Posted by vargai View Post
    Thanks.
    Is Chai a contact person or place?
    Chai is a person
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #12
    @bmbaz, This grease is the right stuff at the right price, http://www.toolstation.com/shop/p89691 , unless you intend to use oil.
  4. #13
    Thanks eddy,yes I use toolstation for a few things because of price and proximity.I can now confirm that a 1605 ball nut has 17 ball per circuit as does a 1610,no idea why mine had one missing,it happens.I think i'll be using Wurth lithiun grease as i've a big tub of it from when I use to work for them(a sample,honest)again thanks for all the info.just putting finishing touches to a siegsuper x2 with help from Clive on the electrics and hope to post report soon,its only taken 6months or so..as it does:-S
  5. #14
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Baz: You're so kind but you forgot the morel support and the and the banter. ..Clive
  6. #15
    Sorry to dredge this old thread up but does anyone know how many balls there should be in a SFU2010? I've had a little mishap with one of mine.
    The combination of fat fingers, eyesight that's not quite as good as it was, and an ever-shortening attention span has meant that dispite my best efforts the nut will travel fine in one direction but binds up in the other. I didn't count the balls as I repacked them as I assumed I had contained them all but it's looking likely that I may have dropped a ball!!
  1. Ball nut brackets, how big do they have to be ?
    By EddyCurrent in forum Lead Screws, Nuts & Supports
    Last Post: 10-03-2014, 03:50 PM
  2. taper roller bearings vs deep groove ball bearings
    By dsc in forum Linear & Rotary Motion
    Last Post: 10-03-2014, 08:06 AM
  3. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  4. Re-filling a ball nut
    By Robin Hewitt in forum General Discussion
    Last Post: 10-08-2011, 11:32 AM
  5. ISEL Ball nut
    By cncezee in forum Lead Screws, Nuts & Supports
    Last Post: 02-10-2010, 12:11 PM
