09-12-2014 #1
i have designed something and just doing some tests. The part is made from 5mm aluminum and has a detail that is 15mm long and 5mm wide/same as material /
Now the problem lies that the protruding part has to go inside into a couple of bearings with ID6mm, meaning i just have to scrape say 0.5mm from corners so it could fit.
Cause of this, i have to make a fixture and turn the part over. Otherwise the part could be machined only one side /actually both sides, but one side is facing, then flip and machine,thats for better precision/.
And be very careful.
I need a simpler way to do it. I have thought and invented some complicated ways , like:
-making it longer , fit on my small lathe and finish,though i have to search and buy new 4 jaw chuck for this. By the way-self centering or not???
-make fixture , screw this inside, then the round fixture on the lathe and so on.
But i am not happy as it must be precise/ better than 0.05mm/ and it would take quite an additional time for all.
I was thinking, if exists something that could help me scrape it simply to shape by hand, that would self guide the 5mm square to 6mm circle. Or something similar. may be it exists already and i just dont know how is called
Bellow some pictures so you could understand the problem. It seems stupid to flip machine 100 parts only to scrape 0.5mm.
Any ideas?
Roundover finishing - what's causing this..?
By Wal in forum Woodwork DiscussionReplies: 4Last Post: 18-03-2014, 03:37 PM -
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
Need some ideas
By jpcnc in forum Machine DiscussionReplies: 20Last Post: 29-01-2011, 07:56 PM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
