    Hi all, I hope this is in the right area. I need to picture below converting to DXF / Gcode. I'm a little lost ! Are there any kind chaps out there willing to do this for me for me please.
    I would be grateful if someone could help, thank you.
    Thank you very much
    Carl
    Download Draftsight, it's free (plenty of other free drawing programs out there) insert the image as a reference image and draw over it on a different layer. Scale it to the correct dimensions and it's a dxf...
    Neil...
    Build log...here
    Lives in Marple Stockport, United Kingdom. Last Activity: 42 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Gasgasbones View Post
    I would remove your email address from the post and ask to be contacted by PM to stop spam. Clive
    Thanks Neil, which DFX should I save it to, there seems to be a load of options !
    I save them as 2013, only really matters if you're sending to someone else who can't open 2013 files...
    Neil...
    Build log...here
    Carl, try this, used Inkscape to vectorize it then CamBam to clean up a few bits.
    Attached Files Attached Files
    G
    Hi Eddie
    Thank you, that works a treat.
    Ill take a look at those programs as well as Draftsite.
    Carl
    Cheers.
    First attempt. I will need to fiddle about with some settings and get a smaller engraving cutter as its cutting into some other lines, That's not a problem though.
    Cheers Again
    carl
    Maybe use a V cutter and don't cut so deep
  1. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
  2. NEW MEMBER: Jig angle head expert look at my PICTURE please!
    By hoezap in forum New Member Introductions
    Last Post: 25-07-2012, 05:09 AM
  3. mods picture and site logo
    By motoxy in forum General Discussion
    Last Post: 26-04-2012, 01:09 PM
  4. Microcarve picture carving software
    By cnctoybox in forum CAD & CAM Software
    Last Post: 26-03-2012, 07:00 PM
  5. Tapping Gcode
    Last Post: 14-12-2010, 07:07 PM
